Yup.1500 cfm fans & you are complaining about overheating. What a joke. A 7 blade, 19" mech fan, pulls over 6000 cfm....
I never read the whole thread sorry.Pulley diameters different than the originals.
Yes, the 7 blade fan with a clutch worked great on my RR. I even have a spare fan. But it is not how I went on the Dart, not having the room. Thanks for the input.1500 cfm fans & you are complaining about overheating. What a joke. A 7 blade, 19" mech fan, pulls over 6000 cfm....
Okay, so stupid question then, if those are the only two reasons for the bypass hose, why cant we just eliminate it altogether?I can tell what will reduce temps....
For reasons known only to Chrys, they used a huge bypass hose & fittings on the SB engine. Hot coolant returning to the rad to be cooled is being diverted just below the t'stat housing via the hose...to the inlet side of the pump. So the cooled coolant that is about to be pumped back into the engine is getting hot coolant mixed with it. The engine is getting warm coolant, not cold coolant!!
There were two reasons for this engineering:
- pressure relief in case the stat jammed shut
- reduce engine warm up time.
In the BB engine, the 'bypass' is a 1/2" hole in the housing below the stat, much smaller.
I would put a restriction in the bypass hose that has with a 1/2-5/8" hole in it. A garden hose brass fitting might do the job.....or put a restrictor in one of the fittings that the hose fits onto....
What bore and stroke gave you a 426. I Did a 4 inch stroke and a 4.165 bore That was a .125 over bore for a 428. X-blockmy 426 stroker and 340 both run cool with stock rad shroud and clutch fam never overheats no matter the temp outside , sits in city traffik runs 190 max , only thing that overheats is me . I figure the factory knew what they were doing
the 426 was made off a la360 1976 block don't remember the specs it was 2 strokes and a brain seizure ago . I WOULD NOT STROKE MY 340 BLOCKSWhat bore and stroke gave you a 426. I Did a 4 inch stroke and a 4.165 bore That was a .125 over bore for a 428. X-block
Okay, update on my over heating saga. Took all of your input and started tracking down items. I ended up putting on a different water pump. The Milodon #16250 definitely moves some water. And I found a used 7-blade viscous fan and put it on. It definitely helped, I have not driven the car yet, but I know it's better, had a 40 degree drop across the radiator. I know the viscous clutch need replacing. Debating about putting a regular fan on instead.
Same here. Mildly built 340 here also, factory rad and shroud, 5 blade fan runs a steady 165, when sitting in traffic more she'll creep up around 185 or so. Seems that when I read about overheating, there usually seems to be an aluminum rad, or electric fans, with maybe no shroud, and(possibly) a serpentine system involved.my 426 stroker and 340 both run cool with stock rad shroud and clutch fam never overheats no matter the temp outside , sits in city traffik runs 190 max , only thing that overheats is me . I figure the factory knew what they were doing
Good morning gents... Im putting together a mild 340 also.
where can i get a spring for my lower radiator hose?
anybody got a link they would share?
Music wire would probably work better, wrapped around a mandrel of some sort. Hanger material is pretty much dead soft. Won't hold shape under pressure.Make one outta coat hanger?
I got mine at a mustang parts supply shop. It's a pretty common part. Cheap too.Good morning gents... Im putting together a mild 340 also.
Check Inline Tube..that's where I picked up someGood morning gents... Im putting together a mild 340 also.
