Hyper_pak
Old School Chrysler Fan
I got most of the steering column together.
Didn't work on the coupler.
A couple of issues I found.
First and almost depressing, I broke this little circlip.
It fits in front of the lock wheel in one of two groves.
It's not shown in my FSM.
So I clipped in the second grove closest to the top of the steering shaft.
That was incorrect as it would not let the upper bearing go in.
So when I popped it out, it broke.
But for the life of me, I do not see what it does.
So I left it out, not that I could find another if I needed to.
The turn signal unit has a ground down roller ball, so the horn might not work.
And one of the cancel cam is cracked so that might be a problem.
Maybe tomorrow I will build the coupler and stick the column in.
