AFR will be cheaper
but the trickflow is
and betterAFR will be cheaper
and betterHave you or heard of anyone try to flow the exhaust port with headers attached ? I wonder what the outcome would be, I guess that’s what their trying to represent with the pipe.Although they don’t specify it one way or the other for this head on their website, AFR usually tests the ex ports with a flow tube in place, which would explain part of the discrepancy in flow numbers on that side of the head.
Doing this from my phone so don’t know what the resolution will be. Here’s the AFR vs SM vs ProMaxx on my bench. AFR is slightly better than ProMaxx. ProMaxx is slightly better than SM.
You can get that with a ported XThe promaxx and AFR both show about 191cfm at .300” lift ok their websites.
The Trick Flow is the best value when comparing apples to oranges. You get what you pay for.
AFR was tested with the AFR valve which is back cut. The ProMaxx and SM were tested with a SM valve which was also back cut.Did you use a backcut valve?
I thought the speedmaster would be further down than this. Seems like pretty much a wash.
Looks to be a waste of time and money for sure.That video reinforces my feelings about how unrewarding it is to chase any perceived “low hanging fruit” when reworking the Ede/SM/PM/AFR type heads.
Some of his closing comments were that the heads already had quite a bit of work on them……..and I think the “big number” was like 5cfm or so better.
This is a problem for sure. The Speedmaster head comes with a throat slightly over 90.5% and with a bad valve job. The only way to fix it is going to a larger valve which may not be needed. Throat on ProMaxx and AFR are about the same but at least the valve job is better.Most aftermarket aluminum heads bowl is the equivalent of a hole on a putting green. If you look at Old Iron that's been worked to flow 260 to 270, you'll never get that shape from one of these aluminum heads because the material is not there to begin with... and you start working underneath the Harden seat to get that Venturi shape and that's when the problems arise
Having seen a car swap from a trick flow to a bloomer head and pickup 2.5-3 tenths with zero other changes, I think the best bang for the buck is the Bloomers.The Trick Flow is the best value when comparing apples to oranges. You get what you pay for.
Downside is because the bloomer is a speedmaster casting, the rocker saddles probably need attention, and the geometry is DEFINITELY horrible without a correction kit. Both those things are a non-issue for trick flow in my opinion.Having seen a car swap from a trick flow to a bloomer head and pickup 2.5-3 tenths with zero other changes, I think the best bang for the buck is the Bloomers.
Yes they are more money than the trick flows, but for the difference in money you are gaining a lot more power that you would spend way more money on chasing than the difference in the heads cost. You will never get there with the trickflows( at least that I have heard about
And not that the trickflows aren’t nice heads, but with the bloomers there is zero doubt you can bolt them on and go, and they come setup for exactly the cam you intended to run.
Plus they will make more power if you upgrade your program down the road
Same guy I mentioned having run both heads simply swapped his rockers onto the Bloomers and has had zero issues.Downside is because the bloomer is a speedmaster casting, the rocker saddles probably need attention, and the geometry is DEFINITELY horrible without a correction kit. Both those things are a non-issue for trick flow in my opinion.
Would you use Bloomers for a 450 hp engine build ?Same guy I mentioned having run both heads simply swapped his rockers onto the Bloomers and has had zero issues.
Neither is perfect obviously, better is who knows what.
I know I have Harland sharps, ran them on my Edelbrock heads a few years with no issues, swapped them onto the Bloomers, no issues either. Maybe I got lucky.
Casting quality wise, these heads I have now are WAY nicer than the eddies I had.
I can’t swear to it, but the shop that threw my junk together I don’t think messed with the saddles, or at least he didn’t mention it if he did.
Been on the car now 3 years, although this year kinda doesn’t count..lol, and it’s made some very solid laps
No doubt the Bloomer head is a good bang for the buck, probably one of the bestHaving seen a car swap from a trick flow to a bloomer head and pickup 2.5-3 tenths with zero other changes, I think the best bang for the buck is the Bloomers.
