Kendog 170
Let the boy go !
Is this correct? Uca needs to move back? Why was I thinking forward?
I didn't know that, and I'll bet mine are in backwards. The front end was the first thing I did during the rebuild; a long time ago. The alignment guy said he could barely get caster to 0-1* positive. Now I've got to check.Correct. They used to include the exact opposite directions which were a misprint and messed a lot of people up over the years. In essence, you lengthen the control arm in the front and shorten it in the rear.
They might be, but be careful. I think they FINALLY corrected it after decades. lolI didn't know that, and I'll bet mine are in backwards. The front end was the first thing I did during the rebuild; a long time ago. The alignment guy said he could barely get caster to 0-1* positive. Now I've got to check.
Since I changed my tire size I have an alignment date for Friday. I did offset bushings last year and wasn't impressed with the alignment and couldn't remember if I had them right. Took both UCA's out and checked last night. All is correct.I didn't know that, and I'll bet mine are in backwards. The front end was the first thing I did during the rebuild; a long time ago. The alignment guy said he could barely get caster to 0-1* positive. Now I've got to check.
I've seen a lot and I mean a LOT of incorrect directions in those bushings straight from Moog.People clarified the directions. Moog didn't change the DE-structions. IIRC
That is the same picture I recall from 30 years ago.
Who puts the front of the car at the bottom of the illustration, still that way. Dumb
Also people would install and think the arrows were where the HOLES went and not the direction of actual arrows on the bushings
This has been as far back as 1987......but I will gladly post a pic if I find it.If you find a set of those, post them up. Would love to see them.
Well, I ordered a set in case I had installed mine wrong and messed them up pressing them out. Didn't need them and they are coming later today. I will open a set and take a pic of the instructions. If I remember lol.If you find a set of those, post them up. Would love to see them.
Both have 1986 date & seem the same.The 1986 instructions are for Camber.
The other instruction are for Caster adjustments.
