I have a standard size set of bushed connecting rods with 2.125 small end diameter. I'm considering a forged 4.125 stroke crank with 2.00 small end. Can the bushing be removed & "resized" down to 2.00? Or should I just buy chevy rods?
There is no issues created by using the chevy rods.IDK the answer, but if memory serves me, Chevy rods have side-clearance issues on Mopar cranks, introducing new problems.
I've seen Jim Laroy say .100" or more side clearance won't hurt a thing. lolThere is no issues created by using the chevy rods.
It wont. I mean, think about it, if you got say .0025 oil clearance in the bearing, that controls how much oil is passing through the bearing, the side clearance has zero effect.I've seen Jim Laroy say .100" or more side clearance won't hurt a thing. lol
Chevy rods are 015 wider on the big end, each. I had my rod journals taken out a little wider (1.9 I think with some radius to mate up to the rod) to compensate when turning the diameter down to run the Chevy rods. Maybe the radius on the outside of the rod’s big end rod bore gives room on the standard Mopar rod journal width, but I didn’t want to take the chance. I trust that you’ve built quite a few more engines than me though.There is no issues created by using the chevy rods.
I was speaking generally about using narrower rods. If you dont have ENOUGH side clearance, then that is definitely a problem! The oil has to be able to get out of the rodsChevy rods are 015 wider on the big end, each. I had my rod journals taken out a little wider (1.9 I think with some radius to mate up to the rod) to compensate when turning the diameter down to run the Chevy rods. Maybe the radius on the outside of the rod’s big end rod bore gives room on the standard Mopar rod journal width, but I didn’t want to take the chance. I trust that you’ve built quite a few more engines than me though.
You’d sure hope so! But I certainly made it a point to ask (and probably annoy) the crank grinder since he probably turns 100 Chevy cranks to every 1 Mopar crank…and even less of those Mopar cranks with Chevy rod journals.if the stroker crank is ground for chevy size journals aren't they also ground to suit the width of the chevy rods? or is that too sensible?
neil.
As the Russians say: “trust, but verify”That's what I was thinking too.
Yeah, I think somebody needs to study up.Ive read this 12 times and i keep saying to myself....those dimensions are the Big end??
What's the purpose of using chevy rods in the first place?Chevy rods are 015 wider on the big end, each. I had my rod journals taken out a little wider (1.9 I think with some radius to mate up to the rod) to compensate when turning the diameter down to run the Chevy rods. Maybe the radius on the outside of the rod’s big end rod bore gives room on the standard Mopar rod journal width, but I didn’t want to take the chance. I trust that you’ve built quite a few more engines than me though.
price, availability-- both in type & construction, design.What's the purpose of using chevy rods in the first place?
Options. I opted for a lighter weight set from eagle to reduce overall mass of the reciprocating assembly, which helps to reduce distortion and stress on the crank and the block.What's the purpose of using chevy rods in the first place?
I guess I had a brain fart. The more I rack my brain around it, a 4.00" stroke is easier. The Molnar cranks I've looked at though, the price is the same so I figured why not go bigger.The bushing is in the small end. I am not sure where you got the bushing is on the big end, but that's what you wrote.
I'll save you a lot of headaches, don't use a 4.125" stroke crank. 4.00" stroke is more than enough for 99.9% builds, and you can buy and use off the shelf parts.
I get 4-5 guys a year that want to build a 426" small block because they saw one in a magazine article.
Remember, Magazines and Hot Rod shows are designed to sell parts, not longevity.
But hey it's your party.
Tom
Smaller rod pins on the crank to use chevy rods give more lower end clearance for stroker cranks.What's the purpose of using chevy rods in the first place?
