Mojack
It doesn't look like it should make a difference, BUT that's how I get into trouble. They are tunneled into the bores anyway or is there a venturi effect that might be necessary?
What does your intake look like?It doesn't look like it should make a difference, BUT that's how I get into trouble. They are tunneled into the bores anyway or is there a venturi effect that might be necessary?
Open gasket then.A center divider spread bores, unfortunately I'll have to use the Mr Gasket adapter to make it all work.
No. Throw that junk in the garbage where it belongs. THIS is all you need.A center divider spread bores, unfortunately I'll have to use the Mr Gasket adapter to make it all work.
He has a spread bore Edelbrock SP2P intake. It's in the picture he posted.This type of 4 hole gasket works well with the '68 340 square bore intake and square bore carb.
4 separate holes to seal off.
Yup…..that’s the one.No. Throw that junk in the garbage where it belongs. THIS is all you need.
[/URL]
[/URL]
