DOES THE HDK SUSPENSION K-MEMBER HANDLE BETTER THAN A T-BAR SUSPENSION?
At the same time, it’s not like we are talking about the best way to record videos. :p But we are talking about handling and options/ideas on how. In some ways, it was a natural evolution when some of us concluded that a bolt in kit isn’t a direction we would go.
I have been following this thread carefully and to say it has been extremely informative would be a huge understatement!
Torsion bar suspension vs CO /rack and pinion.
Here's what I have observed.
Both systems can perform extremely well but, for the vast majority of us, to make the torsion bar system work requires replacing or modifying most of the TB system anyway.
It ends up being a long way from stock to get the performance these guys are getting.
Its useless to use TB and factory K-Frame without removing it and rewelding all the seams and installing the required gussets. Boxing LCA's , replacing Upper control arms with Tubular , experimenting with T-Bars , Installing a better sway bar, upgrading shocks, upgrading steering box to Firm Feel specs or going with a Borgeson replacement.
In a nutshell, the members on here who are running TB based suspension have addressed all the shortcomings and ended up with exceptional handling cars.
The aftermarket has also responded and companies like HDK and RMS have executed fantastic handling and durable systems as well but using a well designed and executed bolt in platform that is much easier to implement for the average enthusiast.
I am not in the Autocross expert category as the posters on here but I do have track time on road courses. (Just came back from 4 days at Barbour Motorsports in Alabama) so I get how a well engineered suspension system is needed if you want to be competitive.
As for my experience?
9000 trouble free miles on my Alter-k-ation RMS suspension, normal tire wear, no breakage (Drag racing and "spirited" winding back road excursions ) .
I have no doubt the HDK system would perform the same.
SN 95
Wow!
Another wild build!
Coupla questions..
1. Am I seeing tone rings on the front spindle/hub assembly? Corvette??
2. Also, GM lower control arms?
3. Did you enlarge the firewall or section it and move the trans opening up closer to the cowel?
4. What Upper control arm is being used?
5. How does the front track compare to stock?
6. Fuel cell or stock gas tank?
Thanks Denny.
SN 95 spindles/ later Mustang
Qa1 Camaro struts, no UCAs
Moved entire firewall rearward after sectioning the lower cowl
The track is slightly narrower for the taller tires and low stance.
16 gal 'Cuda fuel tank. Not a fan of fuel cells on street driven cars
SN 95
Moved entire wall rearward after sectioning the lower cowl
16 gal Cuda fuel tank. Not a fan of fuel cells on street driven cars
THAT is some impressive fabrication, a "clean sheet" build if you will. Start a thread on that thing, it is killer!
wait till ya' get the bill for your one-off, custom, super handling full chassis for your grocery getter. After all, you can put a helicopter engine in a submarine...if you have enough money.
Do you honestly think that we don't know the possible costs associated with having a custom chassis built?
Do you honestly think I don't know the possible costs associated with having a custom chassis built?
I don't think I was replying or quoting you, because you likely do, but I'm not too sure about the others.
While I got your ear, I'm curious.......other than the high dollar spindles (corvette?) , can you elaborate why you believe the AME (Art Morrison Enterprises?) front clip you posted is superior over the others (HDK included) on the market?
sometimes....you have to start from scratch. Butch's next build. Whippled 6.4 Gen III / HDK built 28", 2 to 2-1/8" primaries step headers / TCI 6-speed automatic / recessed firewall / raised floor / 9" Ford / 4--link.....all in a low to the ground 74 Duster with flat stock hood .....old school. Oh yeah, forgot....with windshield wipers and A/C.
TRIGGER warning......NOT built for handling but to haul ***. Ought to go 200MPH easily (not with me behind the wheel), Butch has made plans to wind tunnel test to make sure it doesn't "fly"
I forgot you were doing struts on that car.
One idle daydream I had awhile back was an S197 strut suspension swap. There was a '13 Boss at Ford Fest last weekend that was 0.8 seconds faster than Joe, assuming the autox course was unchanged. So they can handle. He was 9th, another S197 ('10 GT500) was 2nd.
Never looked into it, I am sure it would be an absolute bear.
I'd say a front and rear swap off an S550 would be smarter, but those things are wide. Fully half the top 10 LM cars at Ford Fest this year were S550 cars.
The AME kit is built using some proven Corvette based design, geometry and parts. The DSE spindle that AME is using combined with a C7 Vette hub bearing is a superior piece in strength to any candle stick style spindle. Having the upper control arm and ball joint on the underside of the spindle makes fitting wheels wide much easier compared to a shorter spindle with extended ball joints on the top side of the spindle.
Using the Speedway G-Comp diagrams in the picture below shows that the inside barrel of the wheel could be roughly as small as 15.375" in diameter and still clear the top of the spindle.
The Valiant in the picture below is a perfect example of that.
The C7 Vette style hub bearing whether it an OEM piece or following Speedway piece is much stronger.
https://www.speedwaymotors.com/7thG-VETTE-HD-MOLLY-FRT-HUB,582469.html
I would go to all the trouble of going to an AME bolt in setup, a DSE front clip or a Speedway front clip just for the sake of going to get groceries.
I know for a fact that the vast majority of HDK, RMS, QA1, or Bolander customers are doing just that. Going for ice cream or to Walmart. Which there is nothing wrong with. But they aren't out beating the hell out of the car and drving it to any kind of potenital.
I'd only be getting away from torsion bars to build a purpose built high performance street and track machine or in a drag racing application where the bolt in coil over kits offer much more room for header and turbo kit clearance. Even from a high performance street and track machine, I don't see that much of advantage of swapping to any of the bolt in coilover kit offerings other than clearance for headers.
I'm all for upgrading parts and making a car better for it's intended purpose. But if the parts that are currently offered are no better, aren't stronger and more durable, etc., why bother spending the money? There's honestly still no real proof that installing any of the currently available bolt in coilover kit will make a car a better handling street machine or track car.
What you describe is effectively rebuilding the suspension. Let me paint you a picture.
Let's say you buy a basic '75 Duster /6 that is pretty well used up. When you pull the suspension apart to rebuild it, you find a LCA pin has broken loose. So you pull the k-frame to get that welded up. Might as well fully weld and gusset it while it is out. Or even better, find a V8 k-frame and get it gusseted and welded before swapping it. And if you are going to rebuild the LCA, why not put poly or better bushings in. And stiffening plates are an easy upgrade at the same time. Bolting the LCA back in, why not use adjustable struts since the poly bushings cause problems and you have to buy parts either way. Shocks are absolutely junk, so why not upgrade? UCA bushings and ball joints worn out? Buy some new ones. Torsion bars all sagged out? Why not put some bigger ones in? Car didn't come with a sway bar, so buy an aftermarket one. Steering box slow and/or worn out, why not a Borgenson box? Other than brakes, wheels and tires, you are done. I don't see that as a long way from stock.
In regards to the gusseted k-frame, I basically went through the above. My '74 had a pin that was breaking loose so I bought another spool mount k-frame and had a buddy gusset it and weld it up. Figured while it was loose, it was the right time to do it and buying another one meant I didn't have to leave the car on jack stands for awhile. Then I swapped my k-frames in a weekend or so. That k-frame then went back to the same friend and he fixed the pin and welded/gusseted that one as well. My G3 swap car is a /6 car so that k-frame got swapped into it. So I now have 2 cars with gusseted k-frames all for $100. Not counting the work my buddy did because we help each other all the time, benefits of a lifetime of friendship.
I think you are looking back at it through the lens of having spent a fair amount of money and kind of blowing it out of proportion. At the same time, I am certainly looking at it through the lens of not wanting to drop all that money all at once. I have other reasons as well, and not going to say the cost couldn't be influencing those reasons even though I don't think so. I just don't see the ROI.
In regards to ROI, and just so I am not confusing anyone on my stand or financial situation, my curiosity with the DSE, G-Comp or full chassis stuff is only that. Curiosity. I don't see the ROI on using one of those options for my uses. The blue Valiant is wicked cool and in my mind that makes complete sense for that build. Maybe integrating a G-Comp setup into the front of a car if I was building an all out build but didn't want to or couldn't do a full chassis like that Valiant. Something like a competition venue where a 315/30R18 is a must to be competitive. I would love to do some of that stuff, but I wasn't born with a silver spoon in my mouth so I just don't see it on the radar.
With all due respect DionR ,
That puts you in the 1% of members who have intimate knowledge of suspension geometry, capability with welding, the garage space , the time and the availability of spare parts such as v-8 k-members lying around etc..
As well, you may or may not have to deal with rust issues.
I did most of this and it wasn't much cheaper than going with RMS.
Plus, when I ordered the system, everything came with it, no scrounging for parts, no need to bug my welder friends (again).
And.... the biggest one...I got great support from Bill at RMS when assembling and adjusting the handling to the way I liked.
From the comments I've read on here, HemiDenny supplies the same aftersales support.
Pretty sure Denny would put me at the bottom for knowledge. :D
But I disagree, both with where you rank me and with the need for special knowledge and such. There are 3 parts total that get welded (k-frame and 2 LCA's), and the rest isn't any more complex than a standard rebuild. Making it handle really isn't any secret sauce, at least anymore. The build is pretty basic and common knowledge now.
And I did have a v8 k-frame laying around, but only because I was keeping my eye out for one prior to that. But how is that different than a guy that needs to find one? Even better, don't go looking for one at all and fix/use/upgrade the one in the imaginary car you bought.
And not sure why garage space is a requirement.
I'm glad you like your setup, I truly am. Just don't try and make a TB sound like the impossible dream. Doing so is close to what I told Rusty when I said that there are some that say the only way to make it handle is with an aftermarket kit. It's not that hard.
Of course it does. Like Dion said, it's called rebuilding 50+ year old suspension. Why do you want to compare a 100% brand new system with aftermarket components to original 50+ year old parts?
What's stock about any of the coil over conversions? Nothing. Again, why do you want to compare fancy aftermarket components to stock ones?
Useless? No. Not at all. That depends entirely on your planned use of the car. I ran my Challenger for 70k+ miles with 1.12" torsion bars and 275/40/17's on the street without touching the K member.
Now, will I gusset and seam weld that K before that car goes back on the road? Absolutely. But I'm not planning on using the car like most people do.
Same thing again. Why do you want to compare a coil over conversion that has all of these parts already to a factory stock system?
And then, let's look at what Tim has done. Well, he's experimented with spring rates. He's upgraded to a better sway bar. He has a brand new rack with his brand new HDK. I guess he hasn't switched out shocks yet, but that's it.
That's what's necessary to tune a suspension. ANY suspension. You could run a decent torsion bar suspension without doing that, again, it just depends on your planned use. There are plenty of people here that just buy 1.03" torsion bars and run them with RCD's and call it a day, and they have decent handling cars. Not anywhere near Tim's level, but you don't need coil overs to do that.
What part of the torsion bar system doesn't bolt in? Everything I've done is bolt in with exception of the K frame welding and gusseting. And there are aftermarket parts and options for every part of the torsion bar system, except for maybe the spindles.
I mean, I run the same UCA's as Tim does. Tubular LCA's, 1.12" torsion bars, delrin LCA bushings, adjustable strut rods, etc. My suspension is just as well designed and executed, and if you leave out the chassis stiffening that I've done, which is even MORE necessary on a coil over conversion, well, what's the advantage? A rack. Some header clearance that doesn't even get you to a different set of headers.
Same. 40k+ miles on my Duster's torsion bar suspension since I rebuilt it. A few less on some of my upgraded parts like my SPC UCA's, but they weren't changed out because of any failures, just upgrades. And yeah, 70k+ miles on my Challenger with a fairly similar parts list. It did have a failure, the CAP tubular LCA, but that was a welding issue on those parts and certainly there are coil over conversions that have had failures too (not HDK or RMS that I'm aware of though).
I just don't see many of the points you're trying to make as valid. There's nothing "custom" about the suspension on my Duster, it's all off the shelf parts with exception of the welding and gusseting I did on the K frame.
That Speedway hub is wicked cool! I had no idea they were doing anything like that.
Hmmm...might have to redesign my fabricated spindle, for the 6th time. :D Assuming they kept the ABS tone ring.
I don't believe the Speedway hub assembly has the tone ring.
Yeah, I don't see them either. I don't think the Speedway knuckle has provisions for an ABS sensor so they might not see a need. Seems like the market would be significantly larger if it has a tone ring.
Little surprised they don't offer them in a 5x4.5 bolt pattern too. But maybe that is coming later.
Special Knowledge would include knowing how to weld, especially with dealing with structural and suspension components.
Your definition of a standard rebuild is much different than mine. If you are just replacing worn factory components, I agree. It's when you start replacing the components with a mix of other Mopar models and as well utilizing aftermarket parts to rebuild the suspension, that's where you guys have the knowledge and the edge over most of us. Its also where a lot of us investigate other options such as RMS and HDK. Its not that the TB system is better, worse or the impossible dream, it's that buying and installing a very good aftermarket system that frees up space and also works extremely well is a great alternative and isn't that much more expensive.
you are correct, and I don't think it is a surprise to anyone that we (the aftermarket) do not build for the " purposed racer". We do not even pretend to.
AND, we strive to offer a affordable product that the common guy can buy and install in an afternoon WITHOUT cutting up his precious Mopar to a mere shell of Mopar outer skin. At HDK, I believe a COC should be reversible, which it is. Plug a couple of holes in the frame and you are back to OEM if that is what the next guy wants.
Butch and I bought this Duster as an uncompleted project with a HDK in it, I removed the COC, sold it, re-installed the OEM power steering K. Then stuck the $5K in a paint job. I put plastic plugs in the six drilled holes created when the HDK was installed. Most would not even know.
knowledge??....you are way ahead of most and have more than enough to be dangerous. You would be more than welcome in my shop any day, I'm sure we would have many a spirited "discussions"
You bring the laptop, I'll bring the tool box.
I’ll bring the beer!
