CHARGING VOLTAGE QUESTION
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
What are the ramifications of running, lets say, a 15 volt charging system output in a post 1970 system (electronic)?
Thanks FABO
A fully charged automotive battery is 12.6-12.8 volts. No need to have a 16 volt alternator output. It will just cause issues.
Inquiring minds want to know.
I had a bad ground on a newly installed electronic regulator and it over charged, 16-17 volt range, boiled the battery, burned out my amp gauge and burned out the headlamps as soon as I turned them on. Lucky it didn't cause a wiring fire.
Think most fsm go up to 15.3VDC for charging at 1200 rpm no load.
Here is a voltage regulator settings chart in my 64 manual.
With the system warm, the battery charged, and a lead acid battery, the default is 13.8--14.2. You cannot change chemistry. The system does not run 12V and neither does it run 15V. Some new systems may "boost" to 15-15.5 briefly to boost the system, but if you run a lead acid battery at that routinely, AKA road trips, you WILL shorten life, and boil out acid
Long term maintenance "float" voltage is a bit lower, and varies whether liquid or gel, etc. I am referring to maintainers, and stuff like radio sites with backups which need long term trouble free no maintenance backups. For lead acid this is about 13.5---13.8V
It does not matter if you are talking about a small lead acid battery in a backup exit sign, an auto battery, or a WWII submarine, battery chemistry is battery chemistry.
Similar although slightly higher for the later regulator
Its important to note this is not voltage at the battery. This a test whether the regulator is doing its job based on the voltage it 'sees'. The voltmeter is connected from the junction at the ballast resistor to ground.
The factory considered up to 0.7 Volt difference from the alternator to the battery acceptable with 20 amps flowing from the alternator and about 15 amps through the dash ammeter to the battery.
When I look at the voltage on the automatic charger, the maintaining voltage is usually around 14 Volt.
What year was that just curious? Electronic regulator by chance?
Actually a little bit of drop on the charging line is not terrible so long as we are not heating something up. If there is drop on the charge line, the only thing that happens is, that the regulator will read low and ramp up the difference
The single biggest problem with either early or late regulators, aside from the weakness in the ammeter circuit, is that the share the power terminal with the ignition terminal. So far as I know, all OEM GM, other than "one wire," and same with Ford, have a dedicated sense wire. This wire, since it is ONLY used for sense, carries no current, which means it should be able to truly and accurately sense battery voltage.
On a side note, I once had a beater 62 FJ-40 Landcruiser, which had a 360, then 340, then 318 over the years, and after buying a Warn 8K winch, I scored one of the large frame Chrysler 100+A units. I bought a 100A SW ammeter, and it would BURY that thing using the winch or catching the batteries back up afterwards. I don't remember, anymore, what gauge, I think no6. I'm fairly sure it was not 4
Hi Folks
Thanks FABO
Inquiring minds want to know :)
The higher the voltage, the more current a device will draw.
Ever notice the headlights are brighter with the engine running, then the engine off?
The battery at best provides power at 12.8 Volts.
The alternator supplies at 14.0 Volts more or less.
The higher the voltage the more current will run though the bulb. And the brighter it will light up.
Give something too much voltage, and it will burn out.
Why?
Power = Voltage x Current.
Voltage is potential energy (like pressure), Current is moving electrons (flow).
Voltage = Current x Resistance. But we can rewrite that knowing resistance in a bulb or a motor is fixed, and we control the voltage.
Voltage divided by Resistance = Current.
V/R = Current
How does that relate to your question?
Increase voltage = more current
and
More current and more voltage equal more power.
As excessive current tries to get through resistance, heat will be generated.
@toolmanmike listed examples of what happens when system voltage gets too high.
Batteries can be cooked by too much current even at 14.2 Volts.
Here is an example:
This battery was too low to start the vehicle.
Connected to a battery charger, the recharge was adjusted to 14.2 Volts.
Alls good, right?
WRONG!
That's 35 AMPS.
Even though the charger's cables can easily handle 35 amps, its bad for the battery.
If not reduced it will boil down the acid and can do other permanent damage.
If this was in a car, 35 amps continuous will also damage the charging circuit connections and possibly the alternator.
Imagine if we charged this battery at 15 Volts and didn't have an ammeter.
We're just going to have to imagine that because because I wanted to recharge the battery, not cook it!
This is why ammeters are on the battery circuit. Everything else if supplied with X voltage, it will draw a known amount of current. But with a battery, the current draw also varies with its state of charge.
They say there are no stupid questions, but this one borders on that conclusion. Don't reinvent the wheel. The lead acid battery was established one hell of a long time ago. The operating parameters are established by CHEMISTRY. Wishing something different does not make it so.
I must say, Del, that you are one of the most respected electrical authorities on this site. I read most of your responses with great interest when electrical questions are put forth on FABO. Your diagnostic and procedural advice is second to none.
I've got pretty thick skin, and am surprised that you would consider a person's attempt at learning "bordering on stupid".
Please continue to provide stellar advice. I always look forward to following along.
14.6 was the max number i was taught years ago over that will bake your battery 13.6 is opitmun
Some battery manufacturers recommend a charging voltage around 15.3 volts in freezing weather. You don't want to run that high once the battery is warmed up.
Thats why most newer cars have computer charging systems
