Ant
I have put together what I hope would be a nice 318(323) for what I wanna call the "the peppy grocery getter project", which is my four door 73 Dart. Awhile ago I wanted to dyno the motor to prove someone wrong, but they did not want to put up the money for the bet and backed off. So at that point I felt no reason to dyno the motor, but as time goes by, my curiosity keep growing. To break-in and tune the engine on the dyno it's gonna cost around $900 usd, but I have heard that it's good way to get the motor right before it goes in the car, and one guy has told me that he dynos pretty most motors he puts together for his customers. My engine is not going to be a HP monster, so should I do it for the curiosity and piece of mind?
Motor specs:
Block: 72-73 LA 318 bored .030 over (323 cu.in.).
Pistons: Cast replacement .030" overbore.(They should be)
CR Ratio: 8.6:1 just about when I measured. Asking the wrong calculator might be higher.
Crank: Stock cast.
Cam: Hughes SEH1620AL-12, which has been recommended a few times on the forums. The specs are 112°LSA, Lift: .330"(.495") intake, .335"(.503") exhaust, Duration @. 050" 216° in, 220° ext. Also installed with a double roller timing chain set.
Lifters: Whatever dlat tappet hydraulic Johnson lifters Hughes recommended.(I forgot)
Heads: 675 casting, ported with bowl blend, guide boss trimmed and narrowed, all casting slag and ugliness removed, throat cleaned up, sharp edges removed from short side, gasket matched to steel gasket and pushrod pinch is blended. It was so much work to get the intake ports nice at least the exhaust ports were quick and easy.
Valve springs: Hughes 1110P with dampers and installed at the recommended height, or at least close enough.
Rockers: Stock with some grinding for spring clearance.
Intake: Edelbrock Performer part# 2176. I did some touching up here and there just to reduce the factory ugliness.
Carb: Edelbrock AVS 650cfm
Headers: Duog's D453 long tube headers.
Ignition: Pretty much stock mopar electronic style with low resistance 8.5mm plug wires and an Accel 40,000v coil.
I did a little more work to the heads than shown, I wanted everything to to be as close to the same as possible and hopefully better optimized.
Motor specs:
Crank: Stock cast.
