When good is not enough, Camshaft time again.
Cam on the way.
Lifters out for refacing
Rockers on the way.
Just waiting for parts to get here. I might be able to get this done before too much snow arrives. If so I will take it to the chassis dyno to see where we are.
The more I think about this, the more I want to address the torque converter this winter. Who is the go to for this? @Mean416 the guy who said it is stalling at 4500 was Andy Finkbeiner who evaluated the datalogs from a dragstrip run. The dyno guy said it flashed or stalled (can't remember which) at 3500 during the runs way back when they were done. Might do the cam first, chassis dyno where we are. then converter and see how that changes things.
DM sent
That would be the preferred sequence of events.
Can you post a pic of a datalog from the track, right before and after the launch, that shows the rpm?
I will later tonight.
need any other parameters as well?
Is there a a TPS position indication on the datalog too?
I’m looking to see what the rpm trace looks like right before, and after you step on the gas.
90% is max throttle and the blades are wide open. Last race 11.7 or so. I don't have the time slip. This is shifted manually with transgo 2 shift kit. Sorry, this one was with the bad o2 sensor. AFR was spiking. I will get another
I’m not looking at datalog screen shots very often…….but, to me……on those two it looks like the converter is flashing 4000 on the first one, and 4000-4200 on the second one.
Based on the fall back numbers after the shift, it doesn’t appear the engine is “driving thru” the converter during the gear changes.
That being said, sometimes what’s fast down the racetrack doesn’t look great on a graph.
There could easily be .1-.2 ET in a different converter, but imo, the current one doesn’t present any obvious problems.
The 60’ times are kinda weak for the “sum of the parts”, which often points towards something left on the table, converter wise.
I’d still try changing the cam and testing, before changing the converter.
The other thing is, I’ve seen situations where a looser converter shows less power on the chassis dyno, yet runs a quicker ET in the car.
I apologize if I came across as throwing your recommendations back in your faces. That was certainly not my intent. I only wanted to explain why I decided to do efi in the first place. My lack of knowledge. Along this way I have tried to explain my methodology which is to change the cam first. Sort that out. Then assess what else could be improved. I never negated anyone’s other suggestions and have indicated that I will put them on the list of improvements, TC, Carb were ones I have said I will change if the results of the cam change do not satisfy. My original intent was what type of cam and specs of such. I tried to emphasize that street manners were important and that expectations were not to maximize power at the expense of street manners. Striking the right balance was my goal.
If you are saying to run a solid lobe with a solid flat tappet lifter, I have never heard that. Sorry for my not comprehending. I went away from a solid roller cam because of reliability issues with the roller bearings during extended street use. They are great for max power during racing but many street miles have lead to issues. If my knowledge is flawed with old info, again, sorry for my naivety.
Yes I did come asking for advice and I appreciate all the help given along the way. I had hoped that just because I chose in the past a different route and then tried to explain my decision that I did not come across as ungrateful. I was wrong.
Fwiw, not an excuse but an explanation, I have Asperger syndrome. If you are unaware of it, it is a form of autism that prevents me from “reading the room”, or form discerning what is meant by someone’s connotation or meanings. I interpret things very literally and it means that my responses are not filtered with the normal rationale that normal people do. Evidently, I misinterpreted the responses yet again. Sorry for that. Still trying to get through this life without offending people. Not very successfully.
I should probably close this thread before I offend anyone else. Sorry for the offense I have caused you and others.
You’re doing a wonderful, methodical job of focusing on a plan and moving through the steps it takes to get through it. Some people want to breeze through the thread and not read everything and suggest nonsense after you’ve made a decision and then tell you you’re wrong. You don’t need a solid roller, you don’t need a carburetor (maybe for testing, and that’s a big maybe). Just keep doing what you’re doing. This is one of a few threads where someone asks for help, the helpers ask for data, and you’ve responded to it with actual good data. Props to you. Don’t close the thread, keep pushing forward. Ignore the bullshit.
Kent, do you have close up pictures of the spark plugs at any point in your time running the engine when the O2 sensor was good? The posted pics are not helpful as you’ve described the O2 sensor failing causing the rich condition. Any pics from dyno runs or track runs?
This is from the dyno run a couple years back, nothing since then
This is the most recent. Timing used to start at 25. Those plugs were from a while back.
So 34-35 degrees at wot if I can see that clear enough on my phone. Did you run timing loops on the dyno? I’m not familiar enough with the TF 240s to know if that’s a normal range but I do know I’ve tuned some NA big block mopars with cast iron heads and they liked 37-39 degrees and sometimes in to the 40s if cylinder pressure was really low. I guess the question is how much tuning was done on the dyno?
I can’t see the graph very well on my phone evening I blow it up but 34-35 would need to be at 7k plus for those heads.
That’s a pretty fast chamber.
If he’s under 6500 I’d think 32 total would be tops unless I’m missing g something.
Look at the plugs he posted in #189. I know it’s hard to see but don’t they look short on total to you?
Is the wire is clean to the shell? It’s hard to see in the picture.
And I can’t see the graph well enough to see if he has a curve in it.
If he does it looks like the first line is his initial and his cruise timing.
I need to look at it on my iPad. Maybe I can see it more clearly on that.
I am not sure at all what the timing or fuel were at with that plug. I will be getting new plugs when all is ready to go with the new cam. Since it is so easy to change the tune during a dyno test, what changes would you like to see for that test. I will make a few tunes to prep for that.
There’s a curve, but only a few degrees. Looks like about 30 initial and 34-35 total.
Not necessarily changes but more so actual tuning. Making runs at different wot timing and seeing what the engine responds to. If your tuner or dyno operator are not doing that they are not doing you any favors.
