Kendog 170
Let the boy go !
Ok, so I'm changing from hydraulic to solid cam and lifters. Heads are on so I check TDC with a piston stop confirmed my balancer TDC aligns at TDC on timing cover. Keyway on crank at two o'clock position. Timing gears are dot to dot. What's confusing me is at this setting the valve adjustment chart says to adjust #2 intake valve. Well see pic. The lifter is already rising. Installing a
