Who makes them? Looking for our 67 cuda 904 and 8 3/4.
Thanks
Steve
Thanks
Steve
Me and you both. I've always used them with the grease fitting, too. I've worn some out so they squeaked and popped, but never broken one.Ive NEVER broken a u joint.
Dana #53228X for the greaseable. 1967 PLYMOUTH BARRACUDA 4.5L 273cid V8 Universal Joint | Shop Now at RockAuto
Not if they are installed correctly.Remember, the hole for the grease weakens them....
I see the "standard replacement" are greaseable and the "HD's" are not. I have used both with no issues.Thanks Mike, I checked last night but it didn't show greasable for some reason. Probably me....
I'm with ya there. I don't see any on that list I would want other than Dana. Most manufacturers I haven't heard of. I don't have a TRW catalog with U joints in it. Otherwise we could look there.Also the greasable has zerk in the cap(cheaper to make) and not in the body. SKF i would "assume" would be quality, BUT they make me leery due to price...
Thanks
Steve
| Brand | Numbers | Notes |
| Chrysler | 4720822 4384514 4364400 3780250 3004900 2298908 1752624 858001 | Later numbers supersede earlier numbers |
| Mopar | D207 D134 D134A | |
| Precision/Moog | 315G 317 (grease fitting in the cap) 245 (non-greasable) | Formerly Torque Manufacturing |
| Dana Spicer | 5-1306X 5-1307X 5-3228X (grease fitting in cap) 5-789X | 5-789X is a heavy duty non-drilled universal joint, without grease fitting |
| TRW | 20030 20030P | Now Federal Mogul. “P” denotes a performance or heavy-duty version. |
| Federal Mogul | 20030P | |
| McQuay-Norris | U1306 U0119 | |
| Parts Master | 315GPM 315PM | |
| Raybestos | 51306X | |
| PTC | PT266 | |
| Meritor | CP1306X CP13061X CP72625-3 CP72625-4 CP726251-2 | Formerly Rockwell |
| Sealed Power | 838-266 | |
| SKF | 1-6301 UJ315G UJ246 | UJ246 is a heavy duty version |
| Carquest | 1-6301 | |
| Neapco | 1-6301 1-6300 (grease fitting in cap) | |
| AMC | 8126636 3114708 | Also Chrysler J8126636 |
| GMB | 210-1306 G5-1306X | |
| Alloy | 1019 41019 | |
| Borg Warner | 114266 1142HD 1142HP | |
| NAPA | 315G |
| Chrysler | 4504575 4057025 3634563 2852175 | Later numbers supersede earlier numbers |
| Mopar | D-169 | |
| Precision/Moog | 316 | Formerly Torque Manufacturing |
| Precision Seals & Bearings | UJ316 | |
| Dana Spicer | 5-1309X 5-811X | 5-811X is a heavy duty non-drilled universal joint, without grease fitting |
| TRW | 20059 20059P | Now Federal Mogul. “P” denotes a performance or heavy-duty version |
| Federal Mogul | 20059 | |
| McQuay-Norris | U1309-HP | |
| Parts Master | 316PM 248PM | |
| ACDelco | 45U0124 19473984 | |
| DT Components | UJ316 | |
| GMB | 210-1309 G5-1309X | |
| Raybestos | DT1309 | |
| PTC | PT231 | |
| Meritor | CP1309X | Formerly Rockwell |
| Rockford | K1309 | |
| Sealed Power | 838-231 | |
| SKF | 2-1175 UJ316 | |
| Carquest | 2-1175 | |
| NAPA | 2-1175 | |
| Neapco | 2-1175 | |
| Alloy | 1020 41020 | |
| Borg Warner | 114-232 114-1HD |
| Precision/Moog | 347 | Formerly Torque Manufacturing |
| Dana Spicer | 25-3244X 5-3244X (old number) 5-527X (old number) | |
| TRW | 20226 | Now Federal Mogul |
| ACDelco | 45U0169 | |
| GMB | 240-0369 215-1309 | |
| Meritor | CP527X | Formerly Rockwell |
| NAPA | P347 | |
| PTC | P347 360 (old number) | |
| SKF | UJ347 | |
| Neapco | 2-0527 | |
| Mcquay-Norris | U527 | |
| Perfect Circle | 527 | |
| Rockford | K527 | |
| Borg Warner | 114527 | |
| Amgauge | 114527 | |
| Allied Eastern Corporation (AEC) | 360 | |
| Xact-fit | XF527 | |
| AAP | 20527 | |
| NIKKO | G5369X | |
| Neotek | 20527DL | |
| MotorMaster | 3133-C | |
| Northern Auto Systems | 847733 |
In general, Spicer (Dana) are the best quality universal joints. Most older replacement universal joints from Chrysler, since they stopped making their own, were supplied by Dana.
Spicer replacement universal joints for the small 7260 series universal joints include the following:
- 5-1306X
- 5-1307X
- 5-3228X (grease fitting in cap)
- 5-789X (heavy duty without grease fitting)
- 5-1309X
- 5-811X (heavy duty without grease fitting)
For more information about universal joint brands and part numbers, refer to the following:
Chrysler “7260” Universal Joints
Brand Numbers Notes Chrysler 4720822
4384514
4364400
3780250
3004900
2298908
1752624
858001Later numbers supersede earlier numbers Mopar D207
D134
D134APrecision/Moog 315G
245 (non-greasable)Formerly Torque Manufacturing Dana Spicer 5-1306X
5-1307X
5-789X5-789X is a heavy duty non-drilled universal joint, without grease fitting TRW 20030
20030PNow Federal Mogul.
“P” denotes a performance or heavy-duty version.Federal Mogul 20030P McQuay-Norris U1306
U0119Parts Master 315GPM
315PMRaybestos 51306X PTC PT266 Meritor CP1306X
CP13061X
CP72625-3
CP72625-4
CP726251-2Formerly Rockwell Sealed Power 838-266 SKF 1-6301
UJ315G
UJ246UJ246 is a heavy duty version Carquest 1-6301 Neapco 1-6301
1-6300 (grease fitting in cap)AMC 8126636
3114708Also Chrysler J8126636 GMB 210-1306
G5-1306XRaybestos 51306X Alloy 1019
41019Borg Warner 114266
1142HD
1142HPNAPA 315G
Chrysler “7290” Universal Joints
Brand Numbers Notes Chrysler 4504575
4057025
3634563
2852175Later numbers supersede earlier numbers Mopar D-169 Precision/Moog 316 Formerly Torque Manufacturing Precision Seals & Bearings UJ316 Dana Spicer 5-1309X
5-811X5-811X is a heavy duty non-drilled universal joint, without grease fitting TRW 20059
20059PNow Federal Mogul.
“P” denotes a performance or heavy-duty versionFederal Mogul 20059 McQuay-Norris U1309-HP Parts Master 316PM
248PMACDelco 45U0124
19473984DT Components UJ316 GMB 210-1309
G5-1309XRaybestos DT1309 PTC PT231 Meritor CP1309X Formerly Rockwell Rockford K1309 Sealed Power 838-231 SKF 2-1175
UJ316Carquest 2-1175 NAPA 2-1175 Neapco 2-1175 Alloy 1020
41020Borg Warner 114-232
114-1HD
7260/7290 Combination Universal Joints
Brand Numbers Notes Precision/Moog 347 Formerly Torque Manufacturing Dana Spicer 25-3244X
5-527X (old number)TRW 20226 Now Federal Mogul ACDelco 45U0169 GMB 240-0369
215-1309Meritor CP527X Formerly Rockwell NAPA P347 PTC P347
360 (old number)SKF UJ347 Neapco 2-0527 Mcquay-Norris U527 Perfect Circle 527 Rockford K527 Borg Warner 114527 Amgauge 114527 Allied Eastern Corporation (AEC) 360 Xact-fit XF527 AAP 20527 NIKKO G5369X Neotek 20527DL MotorMaster 3133-C Northern Auto Systems 847733
Summit Racing has them.
7260
10 in stock
If you put slicks on it and routinely dump the clutch leaving the line. Although you haven't said, I'm suspecting "this" thread is all about something that's 100% STREET, where greasable u-joints will be just fine.
I will be putting a driveshaft loop on my Demon......That scenario has always been in the back of my mind. The car is 100% street.Imagine the damage/injuries if a front U joint failed with the car going at speed.....
