Driver Ed
Member
Hello All:
Assessing my new '64 Daily Driver Dart cooling system. With the rad cap off, I see coolant flow at cold start. So either the thermostat is stuck or does not exist. The car has never overheated, even when running above 200F in traffic. Nothing even showing in the puke tank. I am not comfortable running without a working stat. Looking for help on what make, temp and what rad cap. Here are the particulars:
Engine: 1977 318. Engine built in 1990's with Comp Cams "Thumper" cam(don't have specs but is plenty lumpy at idle). Engine likes 12deg initial timing. Edelbrock Perfomer intake and 600cfm carb. Points dist. No headers. No A/C. Has PB and 904 trans.
Cooling System: Water pump stock. Rad is Mopar #38086. No soldered #tag visible. Both hoses on driver's side. Rad measures 18"H tank to tank, 21.5"W. Rad cap is 13lb. 6 blade steel fan, 17"(+-) dia. No shroud (searching-anybody know a source?). No fan clutch(should I install one?)
I realize these are basic questions, but I've never owned a Mopar or a non-stock engine before. I'm trying to learn, though!
Thanks
Thanks
