67-69 Barracuda Notchback “Rear Air” Defog Vent
mosleyme
Plano, TX
Goes on rear package shelf. As far as I know 67-69 Notchback Barracuda only.
I have a nice pair of original in black:
Go on rear package tray like this:
Usually originals look more like this:
I measured with a caliper, created a model in Fusion360:
Here is a pair I printed in brown for my car, along with material I intend to use for the package tray:
Printing a blue one, low on blue filament so I did supports in brown:
Made a sacrificial piece so the longer leg would print better:
First set of prints:
They look great. Thanks for taking this project on. I believe the rear defog system was a very rare option on the notch's. I've never seen a system on a car other than the one I am restoring. Although I won't be installing them for some time, I look forward to putting a pair in the box with the rest of the defog system parts for installation when I am ready to put the car back together.
Regards,
John
Great work. My buddy does 3D printing and he is printing me the body molding clips, the plastic ones that go along the quarters on my 67 Dart GT Conv. They are very hard to find, and when you take off the molding they tend to break from age. Saved me a fortune. There is a lot of things that can be #D printed instead of trying to find originals.
Maybe no longer, but I use to get those trim clips at auto paint supply stores.
Man that's badass for a hard to find part. How long does it take your machine to print those?
About 4 hrs w/ ASA, depends on settings.
Trying a different setup now to see if I can make an improvement on the surface finish. Still learning the 3D printer part. The CAD stuff is easy, I have done a few thousand parts in SolidWorks and Inventor. Took a few hours to acclimate to the menus in Fusion360.
Learning cycles.
Process optimization.
I do this at work for an entirely different process, but the methodology is the same.
So, calibrate flows, optimize the angle you print, strategically place supports, and tweak the bed and nozzle temperature.
Bambu H2D
Overture ASA.
Using 0.4mm nozzle and built in flow calibration.
Slowed speeds down…
Angling the face 25 degrees from vertical, and 40 from the horizontal. Default supports with extra touch points on backside of the fins.
95C bed, 60C chamber 250C nozzle.
Definitely a learning experience.
Much better results! The "visible" lines in the photos are more subtle than the images suggest.
Learning cycles.
Bambu H2D
Overture ASA.
Slowed speeds down…
Just getting started with 3d scanning and printing. Picking up a Bambu P2S soon. Do you recommend ASA for most interior parts?
I'm curious, this is so different than the rest of the A-body rear defoggers, do you have a picture that shows how all this is connected to the blower under the package shelf?
Never seen one connected. It has the housing that sits under a speaker hole. The speaker sits recessed down a bit. Similar to E-body I assume.
I've seen these before but only on B or C bodies to accommodate a speaker AND defogger. I'm curious how they split the outlet tube to accommodate two flex hoses to two of the outlets ducts - all the rest have a long thin single outlet duct in the middle of the package tray.
I can print a "Y" in about 2 hours...
Not sure if what I have is original or something that got cobbled together at some point. The blower is mounted to the steel package tray panel between the two vents. There is a round hole in the steel package tray and there are a number of small holes in the package tray panel for the blower to pull air through. Those don't appear to be hand drilled, but maybe? The hose off the blower splits into two hoses to go to the vents. Neither of the hoses appear to be long enough to reach the vents if the blower were mounted in one of the speaker holes, but I have not checked them to see if they might fit. The wires to the blower came down the driver's side rail along with the taillight harness, then were clipped to the bottom edge of the steel package tray panel with clips that looked like they might be oem. The wire does look to be long enough to reach the blower if it were mounted in the right-side speaker hole. There were speakers in each of the speaker holes in the package tray for a tape player that I added when I first owned this car in 1972. I don't remember moving the defogger blower and modifying the package tray, but it was a long time ago.
John
JohnView attachment 1716511560View attachment 1716511561View attachment 1716511562View attachment 1716511564View attachment 1716511565View attachment 1716511566
going to guess "home made"
