dodgemahal
I installed a new radiator into my 63 Dart. It seems like a quality piece. It's thicker than the original. Now the fan blades are about 1/4" from the core. Is that too close?
I did exactly that once. Cut the core right out of my radiator like a buzz saw. Made me sick. Plus it was around $800 to fix it. Lesson learned the hard way.One thing that should be considered is the the blades pull toward the radiator as they pull air. I had a friend that installed a thicker radiator in a car and when the RPM's came up he destroyed the radiator.
YES!I installed a new radiator into my 63 Dart. It seems like a quality piece. It's thicker than the original. Now the fan blades are about 1/4" from the core. Is that too close?
Oh, heck no! I'm convinced. My spacer is only 1" thick. That might be hard to shorten. 66 valiant528 had a good idea to move the core away from the fan by re-doing the brackets. I'll let you guys know how this sorts out.you don't want this
and you'd be surprised how fan blades move towards the engine with rpms
Don't try to shorten your spacer- just get a shorter one. New or place an ad on the forum for a used one.Oh, heck no! I'm convinced. My spacer is only 1" thick. That might be hard to shorten. 66 valiant528 had a good idea to move the core away from the fan by re-doing the brackets. I'll let you guys know how this sorts out.
For heaven's sake, don't try to bend the fan!! you could weaken the blades or throw it out of balance trying to do that- and you don't want to see what happens when a blade fails at speed...Shorter spacer = great idea! I tried bending the blades towards the rear, but there's so many radius and creases in the metal you can't hardly do it.
https://www.ebay.com/itm/389957660704?_skw=1/2"+fan+spacer&itmmeta=01M08WFKGTP8XZXFBY9RN7ZXA4&hash=item5acb49b020:g:mi8AAeSwh5lp85L0&itmprp=enc:AQALAAAA0GfYFPkwiKCW4ZNSs2u11xAgo3L17J7oHakGSzxyET+HtIzFLGSkNErP43Jwa7qlAZXEnDl5x2SZseljdDklmVVkYvRf/oecUAgAXO02N1IcHPLUbF4KTR8HpkZ7TUIaluSOZq5hw3XHmzS8EWFcJVQcQEf5I7jxRILEP15bnepJbflJd5e+QCTkbM0hQiUElbwC/YW9zFtqowrNbWpFv/vDoAlw1SN+VSO+7i2z3IEeGYIyL6XPAott2gZ/x9eZRwJpKXH0Oh/CCtq3Gcc16rQ=|tkp:Bk9SR8i4vpyCaA
