fishy68
Tyr Fryr's Inc.
Tracy,
Is your pan still off? If it's on maybe look thru the fuel pump hole and see if you can wiggle the oil slinger. I thought mine was on all the way and it truly felt like it the first time I put it on, but it wasn't. It Fooled me good! It fits so snug that the last 1/2" I had to use an impact to get it against the spacer/ oil slinger and I boiled it the second time also.
Yeah the pans off and it had the oil slinger pulled up tight. At least it sure looked like it did. Maybe I'll try it again to make sure as it sure seems weird there is so much diff. between yours and mine when all the parts appear to be the same.
