you've got to be kidding ,damn I hope my 408 runs a 70View attachment 1715104276 we just finished dealing with a few issues in a new build we did for my sons 1970 Duster. It’s a .030 over stock crank 360 with. 600 lift roller cam and a set of open chamber 340 Edelbrock heads I had laying around that I ported and a 340 Victor intake I ported. The engine also has a set of JE flat top pistons. It’s has a 727 transmission and caltracks wilth 4.10 gears. Yesterday it ran a 6.58 and a 6.56 and today ran a 6.54. Pretty satisfied so far and I hope he can go a few rounds in tomorrow’s race
What is the weight and MPH. If you don't mind.
Hot Metal said:You sure are a wizard with cyl heads...thats around 10.40@129 in the 1/4....jeeze we got guys here who are only running a bit quicker than that with 493/500 BB motors
Thanks but I’m just a guy who loves porting and doing flow tests playing with new ideas. I used to do some work for friends over and the Winter months to supliment my retirement and would tell them to start dropping their heads off in October but they would hold off till March so I quit taking in work
What does your bench say they flow ??Those dog gone stock stroke 360’s run pretty good when set up right. He had my old 408 in his Duster last year for a few races with the same set of Edelbrock heads he is using now and ran a 10.08 in some bad air. We are going to build one with some more compression to see how much that helps
That thing is a beast!! Great job, and I'm sure your son is as proud of it as you!!!
my 18 year old and myself will be running his first 7.0 index race this Saturday
He will have the driving duties
I never really thought I could enjoy racing more then I already did till he started showing interest
Great times going on here super build sir
Folks are paying a lot of money for heads that Are capable of making that kinda power Most 408's aren't making that with a factory port design at least
I seen a lot of dyno numbers that say they do but not very many time-slips
To back it up
I check calibration evertime I start a different head and a stock Edelbrock head on my bench maxes out at 243 cfm. This set of heads flows a touch over 315 cfm with a 2.08 valve. I ordered 8 (.350) offset intake rockers for the set I am doing next so I can push the pushrod over
