Updating my Dakota this winter that I built for my son to race.
Old combo was
360 10.64.1,9.5 converter,4.10,solid cam 254@.050 .560 lift,j heads,1 3/4" headers
Best in real good air was 1.49 60,7.0s 1/8,11.0's 1/4 @ 118 I think.It started slowing down at the last half of the season so all the more reason to put a stroker combo together.Tore it down a few months ago and number two main bearing was chewed up pretty good and number one rod small end bushing has some play that was noticeable.
New engine is going to be
416 12.43 compression unless we mill the heads
Icon flat tops
Molnar stock size rods(just showed up Friday...was getting a little nervous this build wasn't going to happen this winter)
K1 4" crank
Trick flow heads and intake
Custom erson solid cam(I had the cam made for 1.5 rocker but now I also have 1.6 harlands so depending on some clearance is probably what I will run)
Same header1 3/4"×3" headers
New fti 8" converter said 5600 stall(904)
Same dana s60 4.10
Have a pro systems 750,quick fuel 950 and a custom e85 carb we could try
3170 race weight
My machinist is trying to talk me into using his dyno so we will see.
What do you guys think it run?
Thanks
