Hersbird
Or they could simply index the bars and they would work as if an engineer designed them...
Good luck, I hope they work for YOU. The problem with the adjuster being that maxed out, among other things, is it can actually hit the frame rail on compression. My buddy had the Mopar .810 drag bars in his Dart and when it would come down from a wheelie those adjusters would once in a while catch the frame rail and get STUCK there and not allow the suspension to even return to ride height. He went with .890 bars as a result. NO BEUNO. I'll spend an extra $150 for FF bars that work perfect any day.
I know that some of you have expressed opinions about our 1.03 torsion bars whether they are good or bad we do listen. Here at PST we have sold 499 ever of our zero clocked or flat-flat 1.03 torsion bars and 51 sets alone just this year with no returns.
We are at the reordering point with our forge in the mid-west (Yes PST's torsion bars are made in the USA). We have made the decision to add clocking to this run of our A Body bars. There will be a 15 degree offset added to the bars. The new design will allow for more adjustment. We hope have the new torsion bars in within a week or so.
Thanks
James
So you guys did listen. Glad to hear and I'm glad I waited. I was looking at a set of your bars but held off to see if you corrected the problem. Perhaps I shall now reconsider my T bar choice. :happy1:
Thanks
James
James clue the sales team in i literally called first thing this am n the guy said new batch was same as the old so i ordered some 920s from summit i have since called summit n cancelled n ordered 103s from y'all
