racingsnake440
- Joined
- Aug 29, 2005
- Messages
- 343
- Reaction score
- 47
I've collected most of the parts i need for the new engine for my Dart and wanted advice on a few things.
I have:
fresh .030" over short block
magnum heads milled .030" and redrilled for LA style manifold
mopar performance thin head gaskets
Edelbrock LD 340 manifold
Weiand Action Plus manifold
Holley 600 and 750 cfm vac sec carbs
Thermoquad carb
Undecided on the cam, probably one of the following:
Comp Cams XE268H, Comp Cams 270H Magnum or Comp Cams 280H Magnum
Unsure on valvesprings/ retainers etc
I'm guessing my compression to be about 9:1 but haven't got anything to cc the heads and combustion chambers with. It's going in my 63 Dart which can't weigh more than #3,200? with 3.23 gears and a 4 speed with manual everything so I don't have to worry too much about idle vacuum.
Steve Dulcich used the 280H in a 318 buildup and i figure that what my motor lacks in compression will be made up for by the extra cubes to make it work ok. However I'm concerned at how well the stock rocker gear will stand up to aggressive cam profiles. I do about 15000 miles a year and want to get at least a couple of years out of this motor. The 318 article state that the magnum head has a good flow balance and favors a single pattern cam but I'll be running Durango manifolds as I can't afford headers and wonder if it might be beneficial to have some extra lift and duration on the exhaust side?
Finally valvesprings - I know there's not much selection for the magnums. Do Mopar Performance P4876062 or P5249464 use the stock retainers or do I have to use 2.2 retainers?
Sorry about the length of the post but basically I'd like opinions on the best cam/valvesprings/retainers to use (bearing in mind this is on a very low budget) to get as close as possible to running 13s and getting 15mpg.
Thanks
I have:
Thermoquad carb
Thanks
