1964 Dart Wheel Swap
Those look nice, but what's your bolt pattern? Standard is small bolt pattern, 5x4"
I picked up sbp cragars for mine, here on fabo, they are sold new also.
If you want new, there are several companies that make SBP alloy wheels ~$170 ea. Search for posts here. Like chewy, I bought a set of SBP Cragars, plus a set of slotted mags. My 64 Valiant came w/ newish spoke wheels w/ big spin-on center nut, but the part that bolts to the hub seems a bit squirrely. There seem to be plenty of nice sets of SBP wheels out there since so many people change to BBP.
Thanks for the direction. I will check out what may be available.
BTW...I have done a front disk and rearend (8.25) conversion to LBP. I am in process of doing a small block conversion. /6 just isn't doing it for me.
