Pictures are worth a thousand words. Yes you need some text but far too often people get carried away with unnessarry text.
Got some work done today. Evan came by as promised. While he was pullin the gas tank, I started on the brakes. I didn't even look when I pulled the drums, but the thing has NEW SHOES all the way around. The drums were paper thin, though. I replaced three wheel cylinders. Why not four? I'll tell you why. Because leave it to ME to get a wheel cylinder with the bolt holes drilled, but NOT THREADED. LOL
Anyway, Got the wheel cylinders on that "I could" lol. Evan got the tank out and there was maybe a gallon in it. Probably less. To our astonishment, not only was there NO RUST, but there was no sediment or dirt. While the outside of the tank looks 54 years old, the inside looks NEW. The sending unit is also very clean and tested GOOD. I ordered brakes hoses too, but they are not here yet. Once they get here and the new hopefully threaded wheel cylinder, I can have brakes. Tomorrow, I am going to put the master cylinder on and do the tune up and change the oil.
I know. Text heavy no pics. They're comin. lol
I'll do my best to not make it an AJ how to.
Yes he would! But would he actually do it?That's somethin @Ben Drinkin would say. lol
@67Dart273 Del, here is the ignition box we talked about today. Was great to catch up for a few. It did have a ground wire and the connectors you see. As I said, one was on the positive side of the coil and the other on the negative side of the coil. I don't see how it could work well, since the coil doesn't see 12 volts. Thank goodness the original wiring harness was untouched. It is LIGHT for its size. Here it is in all it's glory. lol If nothing else, it is a good wall hanger for gadgets from the past.
The other popular CD back then was the Tiger SST. At least some of them were enclosed in a distinctive circular enclosure. I had one, ran it on both the 440 Roadrunner and the 64 Dodge, but never got a tach to work. I ended up with a hemi dist. and cable drive Jones/ Motrola tach
Did it fit under the hood? Or did it take the place of the passenger seat? Lol
Rusty "that thing" is the 70's version of MSD, without the "M" In other words it's a breaker points triggered CD ignition. The reason the weird wiring going to the coil, is that you disconnected the coil power feed, the breaker points, and transferred them to the outer circuit board. This fed the points trigger and the power to the box. The two boards then routed the output of the box to the coil
'Just like MSD' there is no DC power to the coil. The box feeds a pulse..........sort of like an electronic photoflash.........to the coil
Sometimes you have to move the timing light pickup "up and down" the wire, or turn the pickup around the other way
Knight was a kit name for Allied radio.........similar to Heathkit. That box was either Delta or the other popular brand CD I'll have to do some "recollectin" on that
Here ya go............"Delta Mark Ten"
vintage delta cd ignition - Google Search
If you hooked up the "factory" ignition you will want to check coil voltage and be sure the ballast has not been bypassed
