1965 Barracuda Resto from Germany
Your 65 is looking GREAT! Keep the pics of the awesome work coming my friend!!!
THX brother and sister´s for your comments . Fabo it´s the best please on earth !
Next little step
behind I have installed konis red
Cheapo Cupholder installed
new Bearings in the disc brake reduced
K member it´s ready to installed
"" If the father with the son "" mine dad helps me if he is able to
I have done a mistake,torsen bars had no tension :-(
"Learning by doing"
so repaired the problem:)
Tyres "225/60/15" and rims "7x15" fit under the fenders
Hello Uli. Your making great progress on the car. I see you went with wider tires since your last update. Now where did you get those tire sizes from? Any problems with getting the 225/60 to fit in the rear? I ask because I had to use the Mopar offset shackle kit to gain clearance at the spring. More pictures please!!
at the moment these are Tyres "225/60/15" and rims "7x15" in rear
In future have to go 245/60/15 on 8x15 rims 4" or 4.5" backspace
Uli it looks like you have room {to the outside} for a bigger tire/rim. Have you moved your springs inboard? Looks like you have more clearance at the spring than I do even with the offset shackles I have. Your inner fender well will limit the amount of backspacing you can add to the rim so if you go with an 8" rim you probably will have to go shallower (less) backspacing than a 4.5" maybe even less than a 4". I researched every rim I could get info on to try to get a 8" rim to fit but gave up when I found my rims at the salvage yard. My inner fender well is the same distance from my tire as the spring is {see picture, sorry the angle is a little off}. I really want a set of original Torque Thrust D rims but the $ is not there right now for such an extravagance.
Hey Uli, you,re doing great progress on your Barracuda. Would be nice to see it live at Mopar Euro Nats! Or Mopar at the Strip in Orsa Sweden.
Hi brothers and Sisters ,
i have done a few little steps .
Trunk seel done
The rear site windows done
prepared to insert
Cable for mass finished!
My new wiring is comming
more radiator is cleaned and varnished
Great job Uli.You're going to be finished before you think you are.Like the grey with the red.:thumrigh:
Hi brothes and Sisters,
this weekend I had birthday so we had small party ,and the day after we have welded the Hod rod of a friend .
Absolutely cool presents from mine best friends and the family and my Wife spent me a EZ - wiring for my fish :)
Day After
and than we have a little fun my friend Tom give us a rubber bounty ( :)))
a little movie for you
http://www.myspace.com/video/rid/109067661
"Badart " THX for Happy birthday !
Next little step i have done !
Many new pics
I have to obstruct the oil cooler
4 bolt main kaps have come
to obstruct the shifter
engine mounting prepared
i am cleaned the gearbox from the outside
i am to obstruct brake hoses and brake pats
To next weeks we want to insert the new wiring harness
I am install cheap door seal ( They come from a Seat marbella) :))))
Next cheap parts comes to me THX FABO brother
bbp 8x15 Steelis 4,5 backspace it fits with 245/60/15 tires
install shocks
i am inatall trunk lock
inner fender
kick panel from 71 valiant
Great work Uli. Hope that when you do your wiring it really it gives you no trouble.
Happy Birthday Uli!!! I sure hope you took the day off ... looks like you deserve it. Keep up the great work! :-D
I know you're planning a trip to the states next year. Are you bringing the car?
