1965 Barracuda Resto from Germany
I see you got some snow down there too! Here in Northern Sweden we got 1 feet of snow and had -40 degress Farenheit. or -40 degrees Celsius. Boy, that's far to cold. Al of a sudden Hawaii seems ok for me!
Where in Germany do you live?
Hi 65dartcharger
with us these were only - 18 degrees Celsius
but my coffee has also frozen.
I also like rather the summer!
Near Hannover it are so approximate 2.5 hours by the car to Hamburg.
Greeting
Uli
Even today a little bit made.
to do a presentation built around Sicken in the metal
Afterwards still the rear end metal of the spatula with relief and roughly baggy.
Afterwards the lower part bored and cut out.
Then this is as the next in it.
in the end still a pair of pictures from below :-) work calls
OOOOOHHHHH YEEEEAAAAHHH, more metal work!!! You're doing a great job Uli, keep motivated and keep those pictures coming. :cheers:
So today it went on.
Aerial guide plate:????? I think so this is called
Reserve wheel hollow:
From 2 make 1
It´s Done
Special greetings to all Fabo Member
Greetings
Uli
You are really staying busy! Great work too!!
What are you using to bend and shape your metal with?
I had the luck of the previous owners one more Slant Six had slaughtered.
Thereby are there enough shares which I can use.
bend otherwise everything about the vice.
this went really very fast!
If my package has not come yet with you!
I haven't seen it yet, but the holidays really slow the mail down on this side of the world. I can't wait to see what you sent me.
I've got another little surprise for you too ... watch for a package from me soon!
Hi Leanna,
slow the mail down on this side of the world :-(((((
However, there I am already glad!:-)
I wait to full unpatience .
Next step
the first try tin-plate!
Greetings
Uli
so pictures of the today, a visible place still on the side.
then it goes to the other side.
Window frames behind driver's side!
Inside tins also immediately with was clear, if nothing else has seriously expected.
Tomorrow this is finished!
hello Flo nicely you here in the FABO.
if you have looked after 318 Engine !
If he is still with you for me!!!:-))))
Greetings
Uli
the last holiday day!
again pair of steps closer in the aim!:-)
Thus prepare for the ground tins!
Water tank kerbside & A - column!
the first step of other side !:-)))
Greetings
Uli
looks really good :thumblef:, hope to see the finished project on a german mopar event
Your doing a great job PapstX,I think it,s great that your working with what you can find!Keep it up,you,ll be at the shows in 2011.
