1965 Dart unknown hole.
Early A-Body Discussions
  1. Stumpy
    Stumpy Well-Known Member
    52
    41
    Aug 10, 2020
    WA
    Local Time:
    2:10 PM
    What is this hole for in my 65 Dart? AC related?
    Thinking about putting my manual choke through it.
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    54,159
    39894
    Jan 18, 2006
    Iowa
    Local Time:
    4:10 PM
    Automatic car?
  3. C130 Chief
    C130 Chief Mechanical Genius
    3,067
    225
    Nov 23, 2005
    Boise, ID
    Local Time:
    3:10 PM
    Nope, for 6-cyl throttle linkage.
    • Agree Agree x 12
    • mopowers
      mopowers Well-Known Member
      4,978
      2062
      Feb 15, 2006
      West Sacramento, CA
      Local Time:
      2:10 PM
      Chief nailed it. It's the hole for the slant six throttle linkage.
      • Agree Agree x 1
      • Kern Dog
        Kern Dog FABO Gold Member FABO Gold Member
        4,806
        7074
        May 23, 2010
        Granite bay CA
        Local Time:
        2:10 PM
        Yeah, the automatic cars had transmission kickdown linkage attached to it.
      • pishta
        pishta I know I'm right....
        18,584
        8055
        Oct 13, 2004
        Tustin, CA
        Local Time:
        2:10 PM
        V8's had cable as well as 6 A/C cars
      • RustyRatRod
        RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
        65,727
        39033
        Jun 7, 2010
        Georgia
        Local Time:
        5:10 PM
        Yes, that's for the slant six rod throttle linkage.
      • Stumpy
        52
        41
        Aug 10, 2020
        WA
        Local Time:
        2:10 PM
        4-speed 273.
        • Like Like x 1
        • Stumpy
          52
          41
          Aug 10, 2020
          WA
          Local Time:
          2:10 PM
          So i imagine it is a good place to run my manual choke.
          • Agree Agree x 3
          • 65 Dartman
            65 Dartman FABO Gold Member FABO Gold Member
            11,757
            3303
            Sep 24, 2006
            Strasburg, VA
            Local Time:
            5:10 PM
            Your 65 throttle cable bracket also bolts to the horseshoe bracket below the hole. You can see one of the bolts on the left side.
          • halifaxhops
            halifaxhops It's going to get stupid around here! FABO Gold Member
            61,590
            30269
            Jan 20, 2014
            CENTRURAL, PA
            Local Time:
            5:10 PM
            No! Throttle hole, read above posts.
          • 65 Dartman
            11,757
            3303
            Sep 24, 2006
            Strasburg, VA
            Local Time:
            5:10 PM
            If he drilled a hole through the plate that now covers the hole, I suppose he could run a choke cable.
          • toolmanmike
            54,159
            39894
            Jan 18, 2006
            Iowa
            Local Time:
            4:10 PM
            I remember seeing that but I didn't think my 66 4 speed car had it. Yep it's there. You can see how far away from the throttle cable.
          • mopowers
            4,978
            2062
            Feb 15, 2006
            West Sacramento, CA
            Local Time:
            2:10 PM
            Yes. Since you're not using that hole, it'd be a great spot to run a choke cable. You'll just have to drill the inner plate also, obviously.
          • Stumpy
            52
            41
            Aug 10, 2020
            WA
            Local Time:
            2:10 PM
            I did read the posts. I don’t have a 6. Or an auto. There is nothing in that hole. My 273 throttle is to the right of it.
          • Stumpy
            52
            41
            Aug 10, 2020
            WA
            Local Time:
            2:10 PM
            I also need to run wires for tach and oil pressure. Seems like a decent place for all those things.
            • Like Like x 1
            • Agree Agree x 1
            • toolmanmike
              54,159
              39894
              Jan 18, 2006
              Iowa
              Local Time:
              4:10 PM
              What is that a 1 1/2" hole. Get yourself a rubber grommet or a cap plug. I like grommet's better. They seal better and are quieter.
              • Like Like x 2
              • halifaxhops
                61,590
                30269
                Jan 20, 2014
                CENTRURAL, PA
                Local Time:
                5:10 PM
                Got ya then yes it is perfect to run through.
              • 65 Dartman
                11,757
                3303
                Sep 24, 2006
                Strasburg, VA
                Local Time:
                5:10 PM
                Here is the V8 (and slant with factory AC) gas pedal bracket. The hole in question is behind the large space besides the bottom two holes roughly as I marked
                • Like Like x 1
                • Thanks! Thanks! x 1
                • toolmanmike
                  54,159
                  39894
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  4:10 PM
                  And the smiley face reinforcement on the firewall side keeps you from putting your foot through the floor! LOL
                  • Like Like x 2
                  • Dave_J
                    Dave_J Well-Known Member
                    54
                    61
                    Nov 27, 2019
                    Auburn, WA
                    Local Time:
                    2:10 PM
                    Stumpy, OK, the reason its there on a V8 car is ALL the firewalls are stamped the same, Slant 6 or 273. Then if it was a standard Slant 6 it got a bracket that held that long linkage rod in place. If it was a 273 then it got that foam under the bracket posted in that picture above and the throttle CABLE was routed more left as the V8 was wider.
                    I don't have the link to our favorite Lady building that Hyperpak Valiant Wagon. She is using that hole with the linkage rod.
                    • Like Like x 1
                    • BillGrissom
                      BillGrissom Well-Known Member
                      7,394
                      411
                      May 10, 2009
                      Sacramento
                      Local Time:
                      2:10 PM
                      Exactly. That throttle cable-mount plate looked Rube Goldbergish when I restored it in 1965 Dart w/ 273. Then I got a 1964 Valiant w/ slant six and saw how it began with the rotating rod throttle mount, so the cable plate was a retro-fit to that. Stumpy's car might have a later-year cable throttle fitted to it. I saw an early A in the junkyard like that, obviously a kludged-in setup, probably to retrofit a 318 engine.
                    • Stumpy
                      52
                      41
                      Aug 10, 2020
                      WA
                      Local Time:
                      2:10 PM
                      My '65 has the original 273 4-sp with an 1405 Edelbrock instead of the original Carter 4-bbl. It has a throttle cable that as far as I can tell it is the original set up.
                      • Agree Agree x 1
