dkbug
Been searching through the forums for awhile and figured I would post up and ask about some of the expert opinions on a decent build on my 383.
It's a 67 motor (non hp) and I am wanting a decent weekend cruiser.
I purchased a 20/20 crank with 20/20 bearings for cheap, so stock stroke it is.
I'm not going to invest in upgrading rods and pistons seeing as how the ones in it are like new and in good shape, so I am keeping it stock bore. (to keep the build cost to a down low)
I saw the build they did on the stock 383 in Mopar muscle mag adding an intake, cam, and headers for a total of 455 Hp and 456 ft lbs of torque. Is the combo they ran basically as good as it gets?
Ok, I will get to the point now. What are some good intake/cam combos for a good low end motor.
Stock heads worth a port job?
Dyno sheets on the difference between stock flow and a ported flow on stock heads?
Basically my goals are to keep the build cost down to a minimum. College life sucks especially when part time jobs only pay so much per month.
I have $800 to spend, am I in the ballpark?
WHAT WOULD YOU DO?
Thanks in advance FABO
Dakota
WHAT WOULD YOU DO?
Dakota
