1967 plymouth valiant to 1968 rear window seal and trim needed
Sahuarita, az
I have a 1967 valiant 2 door sedan and I cannot find the 67 one year only clips for the rear window trim. I have heard that I can use a 68 seal with 68 clips and trim and it will work. This is the last thing I need to finish this build. Any help is appreciated! Thanks!
If 67 valiant is same as 67 cuda(check part #'s)then it takes a special gasket and mylar lockstrip(one year only)
68 requires clips 68 style gasket and stainless steel trim instead of mylar gasket.
