[WANTED] 1968 - 197? small block throttle cable bracket (in Ontario)
67CBodyGuy
London, Ontario
Rating - 0%
0   0   0
I'm looking for a 1968 to 1970-something small block throttle cable bracket. If you're somewhere between Windsor and Woodstock then I can pick it up from you, no postage hassle. Send me a PM if you have one you don't need.
Is there really a difference between 2 barrel vs 4? This is what I have now:
That shaft with the U-shaped arm was welded on. This might have been done a long time ago when a polysphere 318 was swapped for an LA 318 and the bracket was re-worked. The U-arm is for the transmission kick-down rod. This bracket has worked for a long time (the carb is a 2-barrel carter) but the end of the shaft is too close to the valve cover so I'd like to get the correct bracket.
The throttle cable hold-down is a little higher and closer to the carb (and the angle is different) for a 4-barrel setup?
But why the difference in the transmission kick-down rod setup?
Why don't you post some photos of you're current setup and let these experts get you a correct working configuration. Easy solution.
And we LIKE photos of engines.
