1968 Barracuda Convertible
I also picked up the radio yesterday. It is now working and I had him install an Aux. connection also while he had it apart. It will at least allow me to play some music in the car as the only AM station in the area that plays music is a "traditional country" station............ how many times can a dog run away????
I've picked up an antenna for the car. The previous owner patched the antenna hole when he was doing the body work. Would someone be able to provide me some dimensions for the location of the antenna hole as well as the size of hole? I don't really want to have to unbolt the fender.
Thanks in advance.
Allan
I'm working on my 69 vert. No dash lights. Turn signals work and headlights also work. We replaced the headlight switch. I guess I'll have to pull the dash and look at the pins and circuit boards. New leaf springs and shocks on the rear. Sits much better now.
NAPA has replacement horn relays.
Whoops. Now I see you already got one.
I see you joined us just last fall so a belated welcome Allan from Sherwood Park. Nice looking fish and I like the repairs and the direction you heading and your trunk de-insulation job looks much better, that was a bit odd. I'll keep watching your progress.
Danny
Mr G for the molding screws, Mr Moparts for the other stuff.
I forgot to ad that the car missing the kickdown concerns me. Hopefully the previous owner didn't drive the car without it. If so I would drop the tranny pan and check for debrie in the pan. Not running the kick down affects the line pressure in the tranny and running without one leads to transmission failure.
The one on the left is for 68 only. Really hard to find
I was having issues uploading to Photobucket so I haven't bothered updating progress .... that seems to have now corrected itself, so here's a condensed update of recent progress
As mentioned previously, the column had a ton of primer overspray on it. I sanded it down, did some masking, and gave it a spray. I do have a HVLP gun, but in this case I just used a rattle can, as I will with the dash before I reinstall the dash pad.
Looks much better! The signal arm was covered in overspray also. It cleaned up pretty good.
.......and the horn now works as it should.
I ended up pulling out the front seats, console and carpet and removed all the "insulation" that had been installed. It just bugged me. The floor actually looks really good. There was a little surface rust on the drivers front floor from moisture sitting under the insulation. I cleaned it up and gave it a little spray.
The previous owner had run secondary wires for the back-up switch. I prefer things original so I chased down the issue with the power to the switch. Turned out to be a bad fuse contact in the fuse panel. I removed his wiring and re-attached the stock wiring to the switch plug.
This was after I fixed a blown apart back-up switch. He or someone had tried repairing it and broke the crimp clips off the switch. It was lying in pieces when I removed the carpet.
I reassembled the switch, mixed up a little JB weld, and glued the case back together, clamped it and let it set. The switch now is reinstalled and works, and it didn't cost me $90 for a new switch.
The carpets were filthy so once out I peeled off the jute backing and took them to a Laundromat (the missus wouldn't have approved of using our machine, lol) and ran them through a cycle. Brought them home and hung them. Left them out for approximately a week with numerous major rainstorms. They came out really nice considering what they started like.
I cleaned up the jute backing and just laid it in position.
With the seats, carpet and console back in, it looks pretty good. When I got the car the console wasn't sitting level. With the interior out I saw the rear bracket was bent. I straightened it and everything sits square now.
I also picked up a trunk mat. I need to cut out a tire well cover and find a narrower spare, but it does look better.
I'm currently working (still) on the dash. I picked up a replacement gas gauge and temp gauge that hopefully work. The printed circuit board is fighting me. I am getting good at replacing pins though! If one more fails, I'm going to abandon the round connector, pick up some wired dash bulb plugs and hard wire the dash with an eight connector plug. I'm done dealing with pin repair.
That more or less brings things up to date.
Allan.
Oh yeah, I also ended up needing to order another top cylinder. The "good one" leaks, so I need to wait for that to arrive and install it before I can finish the install on the rear interior. Probably a good time to try to fix that wonky top install.
Allan
Allan
It happended to me also. The female inside threads of the cylinders are weak. Care must be taken not to tighten to much or they will strip. Keep posting...I'm doing my 69 Fish Vert.
Sorry, I guess I should provide a bit of an update. I haven't updated in a while as the '68 has gone down the road. I traded it, a 57 BelAir convertible project and a little green stuff for this '37 Cabriolet. It's a nice older built car. Original Henry Ford Steel, Big Block Chevy, Turbo 400, Ford 9", Vintage Air, PW, P. Seat, PS and Power brakes.
Hopefully there was some useful information included in this thread while I had the car.
Allan
Hope you have as much fun with your new car as you did with your cuda. Thanks for posting.
