1969 Dart - secret to getting headliner trim to stay?
jcmeyer5
Token Ford Guy
Northeast Indiana
I tried installing the trim that goes along the top and down the quarter window headliner edge. I can’t get it to stay on. It doesn’t want to clip on long enough to do anything. Is there a secret I don’t know?
Are these the clips you have?
If so , you may have stretched them apart too much when you took them off. Squat them together a little more with a pair of channel locks or a vise, they should grip pretty tightly when putting them back on.
use a small dab of 3m weather stripping adhesive with a tooth brush ( on the metal)(I like black...) and some ultra small spring spring clamps/vise grips working both sides evenly TAKE YOUR TIME and let the adhesive dry...
you will be able to drum on it....
69 fb headliner
No guys, the headliner is already in. What I am talking about is the smooth metal trim that goes over the pinch weld. It has these clips in it (or at least very similar).
I can install the clips off the trim, but on the trim they dont want to go all the way on.
yeah, sometimes it's better to walk away /than to break 50 year old hard to find parts...ive used spray silicone (let dry):lol:on some clips before installing them/sometimes killing the friction allows them to set/relax the ones on my car had like a od green coating on them
