[WANTED] 1969 Slant 6 Mopar Performance Valve Cover.
Mike69barracuda
Harrisburg, PA
Rating - 0%
0   0   0
WTB for 1969 Slant 6 (225) Mopar Performance Valve Cover for a 225 Cu. In engine.
Also can someone explain the difference between a baffled and nonbaffled valve cover. I did not take mine off yet to look at the underside.
THX
The baffle is an internal shield covering the openings in the top of the cover. There are many ways to do this, but basically if you pulled the oil fill cover or PCV valve while the engine running, the baffle keeps the engine and oil pressure from spraying oil all over the place.
What do u think I have in my 69 slant 6??? I didn't look yet. THX
No clue. The easy way to figure it out is pull the oil fill and PCV valve and look inside with a flashlight. If you see valves, you DO NOT have baffles.
PICS
one is a breather (bigger one) and one is a PCV grommet. V8's had them cross flowing from breather on one bank to PCV on the other, slants dont have that option. Metal port is obviously oil fill but many times that is function of the breather hole.
