I have a resto thread with lots of pictures including some that are really not related lolLooks good. How about some more pics?
After looking at your build thread, I think your project is just a challenging as mine. You did a ton of fabrication work that looks like it came from the factory.Wow! A lot more challenging than my simple wagon conversion from a wagon to a 2 door sedan delivery (or panel wagon)
I agree, the last picture is my favorite as well. Now, how would it look if you’d slide the rear wheel back about 3”? You have to run a small fuel tank/cell at that point though.Did some more picture studies. Someone said that having the rear triangle window would look wierd and they were right. So it will have just the front vent and one roll up window per door. My favorite is the 5th pic. What is your favoriate?
that looks like a head banger no matter how careful you are getting in or out...at least for me.Here’s a 74 Valiant that was shortened even more than what you shortened yours. This one just has lexan for the door glass.
You know, I hadn’t even thought of that… I’m 6’4” so that may be an issue if I buy it! Oh well, if it’s too bad, can always make it a roadster.that looks like a head banger no matter how careful you are getting in or out...at least for me.
agree and like that both! a roadster would be neat but Mom and dad said I could not have a convertible. so, at 65 I've never owned one. yet.You know, I hadn’t even thought of that… I’m 6’4” so that may be an issue if I buy it! Oh well, if it’s too bad, can always make it a roadster.
I'd give 'em a hundred dollars for it.
What you say is true, but the goal is to be unique. I am thinking about leaving the front vent windows out and have a larger roll up window.I think I would use the original front door, frame, and windows, and just use the part of the rear door as filler. Getting rid of the door contour at the wheel well should make the quarter panel look cleaner. The small quarter window will make it look more like a two door sedan.
the proportions of the door with the rear vent window still there look good, plus you'd have a ready made channel for the drop glass. have you any pics showing a full side view with the big door?What you say is true, but the goal is to be unique. I am thinking about leaving the front vent windows out and have a larger roll up window.
Pics of the long door with and without the front vent window. I plan to leave the front vent window out. This means that I will have to cut the window channel that is part of the vent window and move it to the front corner of the door.the proportions of the door with the rear vent window still there look good, plus you'd have a ready made channel for the drop glass. have you any pics showing a full side view with the big door?neil.
Gee with just a bit more slicing and dicing take about an inch out of the A pillar and split the C pilar at the rear to allow the roof line to be parallel with the belt line . That would be a bunch of work BUT it would make it look so much better and keep folks guessing " Is that the stock roof line ?"
An other thing if you were to use a '74 up 2 door hard top door it would give the channels in the door to support hard top glass , of course you would have to have laminated glass cut to fit along with cutting the windshield .
You're doing great work !
