[WANTED] 1970-71 340 air cleaner/breather (holy grail)
yeager
Brainerd, minnesota
Rating - 0%
0   0   0
Well, Im gonna give this a try. I am looking for 70-71 340 breather assembly. I am willing to restore if needed as long as its straight and complete. I just cant seem to pull the trigger on the $1400 one on ebay. I do NOT need the pie tin.
Anybody got one?
Thanks fellas.
Mopar P4529001 Black Wrinkle Air Cleaner 340 383 440 Magnum HP Dodge Unsilenced | eBay Are you only wanting an original Mopar air cleaner? There is one on ebay for $1395.00 but it is a remanufactured part with a recreated made in Canada stamp.
Thanks for reaching out, the one in your attachment is a standard re-pop unsilenced.. I have about 10 of those.. i need the 70-71 340 only. it is lower profile and has two inlets on the sides designed to align with the hood scoops. Thanks.
Yep no problem. If I stumble on a "real" one I'll send it your way.
What kind of money are you looking to spend ?
Are you looking for one that is bolt on condition, or a fixer upper ?
I have one, that is pristine bolt on condition, that I might be talked out of.
