1970 Plymouth Duster 45,000 miles. BEST OFFER
Plumcrazyfreak
MN
Lost my Job. Regretfully selling my 70 Duster. Im a single father of two & the car must go.
1970 Plymouth Duster. $ 19,000.00 or BEST OFFER.
PlumCrazy Purple, This car is very low miles & has never seen winter roads. Absolutely no rust on the body nor chassis. The car was proffesionaly completely restored. Body off restoration. New Paint 2 years old, Complete new drive train bumper to bumper. Only 1,000 miles on complete restoration. Dyno specs available.
2011 MN Mopars in the Park, Recieved OUTSTANDING in class
New Interior
Custom Seat upholstery. Custom cut padding. No skins.
New carpet, small cuts next to shifter housing.
New Head liner,
New Door panels, Front & Rear
New sill plates,
New rear window panel,
New seat belts,
Dash pad is perfect ( OEM )
New Glove box ,
New cat whiskers,
New Lamps
Ralley 150 mph Dash panel, no cracks, perfect but needs to be rechromed
New Complete Interior & exerior rubber/seal replacement
No cracks nor chips in windows
Exterior: Everything is New & Body is Very Straight.
New Paint Not one Scratch
New Stripes
New Chrome remote drivers mirror
Front & Rear bumpers rechromed, Chrome bumper bolts, not chrome caps
New front & rear window seals, New Trunk, door seals & body plugs
New side marker lenses
New Sharktooth grill, no cracks,chips or repairs.
New lower rocker panel Chrome.
New wheel well Chrome molding.
Lift off Custom Fiberglass hood
Chassis Every thing is New
Front suspension completely rebuilt with Just Suspension components.
Upper & lower control arms rebuilt.
New 90/10 Calvert front shocks
New rear Rancho XL 9000 9 way adjustable shocks.
New Mopar Super Stock Rear springs. with 1" offset hangers.
New Quantum gas tank & straps. 1/2 " Fuel pickup.
Heavy duty torsion bars & Frame connectors.
Brakes: Every thing is New.
New master cylinder
New Front to rear brake lines from In - line tubes
New upgraded SSBC front slotted rotors, 4 piston calipars.
New Rear B body Drums & Components.
Completely new drive train. Bumper to bumper is brand new !
Engine: $17,000.00 InvestedEngine bay is spotless.
OEM 22" 3 core radiator & OEM Shroud.
New Custom Built R3 360 416 C.I. 520 Hp
R3 360 Block Stroked MP P4876796AB
4" Cast Crank MP P5007258
Eagle H beam Connecting rods
Ross 16 - 32 Pistons 10-1
Total Seal Rings
Milodon 30940 Oil Pan
Internnal Pro-Race Damper
Edelbrock Performer Heads 60779 Ported & polished
Indy rocker arms
Cam Motion Solid Camshaft 52564-10+4 Valve Lash .023 Dur @ .050 i = 256.5 E=256.4 Valve lift .54698 Have spec sheet.
Edelbrock 7576 RPM Intake
TTI - 340A - C5 Headers Polished Ceramic Coated. 3" ehaust with X pipe & flow thru mufflers.
950 Holley Street/race Carb
Mallory Ignition 6AL Mallory Pro Billet Distributor, MSD Blaster Coil
Power Master Master Torque XS Starter Have Dyno sheet.
Schumacher Motor mounts
1/2" braided fuel line
Aeromotive electric Fuel pump, Aeromotive 10 micron fuel filter
AutoMeter Gauges Tach, temp, voltage, oil psi with low oil pressure engine shut off.
Radiator over flow bottle
Hurst Line lock
Tranny: Built for Street & Strip
904 Competition Tranny, 2.74 wide gear ratio gear set, Deep Pan & pickup, 999-5 Clutch drum & with 1.75 offset band. Low pressure drop with stacked plate cooler with by pass. Teflon sealing rings
10" 904 A o/s Ultimate Torque convertor with flexplate, 3200 stall. H.D. 1330 slip yoke
T.A. Valve body Manual Reverse Shift Pattern. Trans cooler mounted in front of radiator.
Cheetah SCS Turbo Action Shifter with Line lock control.
New Engine froward Light Wire Harness, New dash to rear wire harness.
Wiper motor is not installed. Car isnt driven in the rain.
Rear end: New
8 3/4 489 Case. 3.91 Richmond Gear set Solid spool, Moser 30 spline axels with 4.5 B.C. Bearing
H.D. Custom balanced Drive Shaft
Tires & Wheels: All New
Fronts Kuhmo 15" with Crager wheels Rears: Goodyear Eagle SS DOT 325 / 50 / 15 with 10 x 15 5.5 bs Cragars
I have all the receipts for every thing listed.
I'm regretfully selling my car because of employment issues. My loss is your gain.
I have over $48,000 invested in this car. Everything is new.... This car has been built with, top of the line products. All performance parts used in the drive train. This car is fast, Low 11.00 1/4 mile & looks awesome. Pictures do no justice.
Save your self $$$$$$$$ by buying a car thats complete.
At 60 mph car runs @ 3000 rpm. Car runs very cool, 30 min at 70 mph in 90 Deg weather car runs @ 180 Deg. Very nice street runner.....
See my Gallery for photos. More photo's can be sent to your e-mail.
Thanks Everyone.
sorry to hear about your job loss
that Duster looks awesome!
good luck with your car sale and everything else.
Damn Scott, that is not what I wanted to see. Hopefully you can keep your affairs in order and find some employment very soon. Kudos to you for putting your kids ahead of your hobbies.
Take care,
Grant
Beautiful car! Sorry to hear of your job loss.
I was a single-parent with two kids for almost 8 years and remember it well. Lots of things done without because the kids came first. You've got your priorities straight and your kids will remember it in the future.
Good luck to you on both your job search and your car sale.
Sorry to hear about your situation. Hopefully something comes your way quickly. That is a beautiful car! I wish I could afford it, good luck with the sale, it will go for sure!
Thanks to all. This is a great forum..Spread the word. The car must find a great home.
Sorry to hear your troubles. You're a better man then me,I would make the kids eat spam before selling my car. Only kidding kids do come first. Good luck with all.
wow, sorry to hear about your situation. Having to sell a beautiful car like that really sucks, There seems to be a lot of folks on here in the same boat lately, with the loss of a job or a spouse with no job. Times are really tuff which frankly is kinda scarry. Lets all say a prayer for these folks, and hope things get better.
The economy sucks. Thank god the car is paid for. The money will help us out. I have a long history with this car.
Pictures doesnt do this car any justice.
Thanks again.
The high bidder backed out. couldnt get financing or something. I kinda got F 'ed on that one. It sold for 21,000. Lots of guys called on this car. We'll see what happens. I realize the market is flat. But for my asking 19,000 its still a steal. You can buy a roller for 7,000-10,000. Only 1,000 miles on complete restoration.
Thanks for looking.
Wow, that is a really nice car and worth every penny and some. I am sorry about your situation, Hope everything works out for you. God Bless!
All I can add, is if the rest of the car is in 70% of the condition of the original hood for it I got off Scott, it's CLEAN!
Grant
Interested parties should know that the complete drive train was built by Lofgren Performance. Engine to rear wheels.
Chuck & his staff won the Purple Oil Hemi Challenge seen in MOPAR Magizine.
This car is well Documented & includes receipts for everything.
I'm eccepting reasonable best offers. NO TRADES .
Car needs to go soon. Out of work . Thanks everyone.
