So over the last two days I have installed the fuel tank with new sender and an exhaust system.
A BIG kudos to Tom aka Dartnut! :cheers: :thumleft::thumrigh: He sorta donated the pipes!
With the new sender the gauge moves off bottom a little, I am hoping it will work when I put more gas in it. I changed the voltage regulator hoping that was the issue with my gauges. When I did that the temp held a steady test light and the gauge went up slowly when the key was turned on.
The exhaust begins with the Flow tech headers, I think that's what they are, and then flows through 2 1/2" pipes to Thrush Turbos with down spouts in front of the diff. I did make a video but it's 39MB!! Haven't figured out how to change the settings so they aren't so big. It's not perfect by far, but good enough for a daily driver. I am now waiting for tires. They will be on next week sometime. I am going to go with 225/60/14 up front and 225/70/14 out back. The rims I am using wont allow me any more width in the rear, so for now this is what she gets.
I'll work on the video now.....
