NormalPcGamer
Hello all,
I've been trying to troubleshoot a fairly new issue with my valiant (past couple weeks)
First off the car
1975 Plymouth valiant brougham
Engine - Swapped 360, stock bottom end (stock flat top pistons), comp XE268h cam, Speedmaster aluminum heads and high rise dual plane intake with a 1" plastic 4 hole spacer, hooker long tube headers, Edelbrock performer 750 carb, about 9.0/1 compression, stock style (new) distributer, MSD blaster 2 coil. Vacuum reading in neutral is about 14-15", in gear its about 10". Electric fan and aluminum rad.
Transmission - rebuilt 904, full manual valve body, stock converter (about 1800ish rpm stall)
Rear end - swapped 8 3/4 with 3.91 gears and sure grip
The issue
When the car gets warm (around 150-180 degrees) the car will stall and shut off when put into gear. (see video - ) I've been driving the car since April and this issue has only came up in the last 2 weeks or so. (note: in the video the amp gauge is pinned, the needle is slightly bent towards the charging side but has always read 3/4 or higher when the electric fan is on)
What I've tried
Timing/ignition
-New cap and rotor, new plug wires and spark plugs (about .036 gap)
-currently its set to 15 initial and 41 all in (I know all in is a lot, the swing in this distributer seems to be about 25-26 degrees, I've tried the FBO limiter plate but had to take it out due to it getting hung up on something and sticking at max advance) (side note I've ran the car at 45 degrees all in and I've never heard this engine ping)
-currently I have one light spring on the advance weights and I removed the heavy spring. issue was the same with both springs installed. issue was also the same with the old distributer.
-Vacuum advance is unplugged (ported vacuum) as it makes the car run worse even before this main issue came up. (manifold vacuum will cause the car to surge while driving)
-Tried both the stock black ignition box and factory Chrysler chrome box with same issues.
-I'm still running the stock quad prong ballast resister, I tried bypassing it today but it got the ignition box super hot so I put it back, issue was still the same either way.
Fuel
-New mechanical pump, new sending unit, replaced the rubber fuel lines front and back, blown air through the steel lines, tank is stock but doesn't deposit sediments.
-I've installed that 3 nipple wix filter in line with a clear glass filter and ran the third line back to the tank to prevent fuel boiling. Fuel pressure is a constant 5-6psi cold or hot.
-Currently I have a Edelbrock Performer 750 (1407) set to #14 on the tuning chart. idle mixture screws are at about 2 turns out. cleaned passages in the carb. idle is set to 900rpm in neutral and about 800 ish rpm in gear
-Found a gas station that sells non ethanol fuel, no change there
-All the rubber line up front has the slip on heat shielding, rubber line doesn't feel hot to the touch
Weird things I've noticed
-The coil when running in idle will read about 2.5 volts. when I bypass the ballast resister it reads about 4.5v. This coil has been on the car for about 5 years now and has never had an issue (maybe going bad? its mounted in the factory location and not vertical like they recommend)
-When the ballast resister was hooked up it would get smoking hot but unplugged the ignition box would get smoking hot.
-When the FBO plate was sticking the engine at 36* all the time its actually the best it ever ran and wasn't shutting off when hot.
-Battery voltage is at 15.5 volts when idling, 12.7 when off, I've replaced the voltage regulator but no change
-I have a A/F gauge installed and when the car stumbles and dies it doesn't go rich or lean, just shuts off.
-When it shuts off it will fire up no problem and sometimes idle fine and sometimes surge in neutral.
Things I'm gonna try next
-I have a Holley brawler 650 I'm gonna put back on the the car and see if that changes anything
-Rewire between the ignition box and coil to bring up the voltage on the coil.
-I'll find the ballast resister that came with the MSD coil and install that (P/N 8202 coil) even though the manual for the coil says I only need the ballast for points ignition.
I'm leaning towards it being something electrical that's causing my issues. The voltage at the coil seems very low so that's gonna be my next step. If anyone has any info on the ballast/coil wiring that I should do please let me know, or if anyone has any other questions/suggestions LMK, I've touched everything on this car so I'm very familiar with the ins and outs with it.
Pic of the car
Thanks!
First off the car
The issue
What I've tried
Timing/ignition
Fuel
Pic of the car
Thanks!
