[SOLD] 1979 360 short block engine motor 4027596 heads
bbrroowwnn
never re member
Drums, PA
I have a 360 short block consisting of bottom end rotating assembly and a set of 4027596 heads...Both heads are there...I just have the one off for the pictures......no rocker assemblies though....It comes as pictured....stock bore....block is dated 4.22.79 the 4 may also be a 1 or 7...not sure...casting number is 4179930-360-10? I took the one head off to get some better pictures....good buildable core if you are looking to build a 360.....I would like a local pickup on this....200.00 OBO
You should put that engine in the Maytag...Your spin cycle would be so good, you could skip the drier....
Tim Taylor (Arg, arg, arg)...
You're welcome bbrroowwnn...
Hey everybody! I got to see and touch the famous Maytag...
It is as majestic in person as it looks in the pictures...
My being is now whole...
