2 bbl to 4 bbl pros/cons?
If you can get the intake and carb cheap enough, put them on the shelf for when you want to build a true 4bbl engine with related parts to take advantage of the upgrade.
The real question is "How far down the rabbit hole will you go"
Carb
Intake
Cam
Headers
Dual exh
Shift kit
Rear end mods
........Your wallet is the limit!
Well that was fun!! Thank you very much for all the input. Some funny. Some expensive. Since the intake and carb are free, I'll get them for a possible swap if I keep the car. I like to keep things simple and as OEM as possible. If the performance/power was going to be more noticeable, I'd do it. But I'll keep it as-is for the time. When I bought the car (online), the pics looked a bit better than it was in person. But it drove far worse than I had anticipated. Just very "loose" driving/steering. Not sure if a new steering gear box will fix it. I'm probably nit-picking it a bit, and comparing it to prior Dart's and Nova's that I've had. Going to see how the summer goes and might put it up for sale this fall.
On a bone stock 318 with duals, stock cam, a 2bb performing UP TO PAR aka jetted for performance without being "black," and as mentioned, the dist. curve redone, you can get a surprising amount of performance out of them. You also might gain a LITTLE if you built or bought an adapter and put a 360 size (bigger bores) 2bbl on the 318 manifold. The air filter base, however will not fit.
I've swapped an actual 360-2 stock intake onto a 318 before with stock 360 Holley 2 bbl and it ran surprisingly good ... Those Holley,2210/2245 carbs as used on the 360 and 400s were a feast or famine game. Some ran great and others were nothing but problems. No "in between".
Don't know why there's so many anti 4 bbl, basically no down sides other than the time and effort, and with recurving the distributor make a nice bump in performance.
I'd say it's the basics for performance you can do to the engine plus exhaust with no real side effects.
Hi. I have a stock '74 Dart 318 2bbl. I was offered a 340 intake with a 4bbl carb. off another mopar. Not sure if it was from a Dart or other model.
Question is:
1. Will this exchange fit without any modifications.
2. Will there be any noticeable improvement in performance/HP?
3. Will it be worth the conversion?
Pros/cons?
This is just an occasional driver. Not daily, but more than just weekends.
Is the manifold off of a pre 72 340? Just asking because the later 340's and 360's used a spreadbore style manifold for the thermoquad carb. The TQ had small primary bores and provided excellent low end performance and great response when getting into it due to the larger secondary size. I used to run a TQ on my 1970 318 Duster and it gave excellent fuel economy.
If you already installed the duals it's like a half done project at this point, go ahead an put the 4bbl on!
Any A body should handle better than any nova in the same condition.
Likely needs front end wear parts replaced.
any carb inlet swap things to consider
1) linkage throttle
2) linkage trans
3) throttle cable routeing and connection
4) return spring set up
5) jets rods springs
6) initial lack of torque until you get it sorted
7) air filter, size, base tin bore, height in engine bay, clearance
8) vacuum connections booster PCV advance, cold running flaps, aircon
9) choke set up
10) how much have your or their heads and deck been cut, has the inlet been faced up for a different motor...how wrong is it......can you cater for it with fat gaskets....
11) do you or will you block off the heat transfer
12) does the inlet have an impact on coolant routing, thermostat housing etc
13) do the ports match your heads or has someone been at it with their favorite rotary tool
14) fuel line routing/banjo/fittings, does it fit with the air cleaner base.
Dave
I too had the dual exhaust (2 1/4" pipes, FlowMaster 40s with the factory exhaust manifolds) installed on the Jaundiced GT about 2 years before my mechanic/friend put the 4-bbl on it (Edelbrock LD4B intake with a Edelbrock 1406 600 cfm carb). My mechanic/friend used Lokar throttle & "kickdown" cables.
My first Dart was this triple green '75 Swinger I bought from the fire chief of my home town (apparently he was tired of red vehicles :)). Picture from around '79.
The old car hobby is not only about owning the car but tinkering with it as well. Its a hobby. Back in the 70s and 80s it was a rite of passage for every teenager and older to convert a 2bbl engine of ANY make to a 4bbl. Commonly, an Edelbrock (Not ELDERbrock) Performer manifold and a 600 vacuum secondary Holley were purchased new from Summit and installed on a Saturday. Even if the car is and will remain a 20 second quarter mile car the sound and feel of those secondaries opening up is what it was all about! I say do the swap. You know you have some fabricating to do to make the kickdown function correctly- That fabbing is part of the hobby too!!!!!!!!!!!!!!!!!! You have a clean beautiful car. I say do the swap. Enjoy the car and enjoy the addition of performance oriented and application appropriate parts.
My two cents on the steering. A few years ago I had a 72 Duster 340 with power steering and the steering was awful.. I have owned many Chrysler muscle cars and nothing was like this. So I bought a Firm Feel stage 1 and it made a huge improvement. My 72 Demon 340 that I have now (also power steering) had a pretty loose steering also not near as bad as the Duster so bought a new steering box from like Napa locally and again a huge improvement. I don't think I can add any extra to what everyone has said about 2bbl to 4bbl conversion. Btw it looks like a really nice Swinger.
Wow. Beautiful motor and car.
I'm wondering if a new steering box will help. I'll have to ask my mech. Seems like it would, and it can't hurt. They went through the front end and only had to replace idler arm. Everything else was good. Didn't notice much improvement.
Very clean lookin install!
Has to be the problem since the front end has been gone through, I've had my Duster since 2007 (I was 16 then lol) and one of the first upgrades I ever did was a Firm Feel stage 2 box, made a WORLD of difference. If I was to do it again I'd probably go with a Borgeson box.
@str12-340 has a point, you could try adjusting the one you have it wouldn't hurt. In most cases though it won't do much and you still have the over boosted, drive-with-your-pinky feel. Although if your PS pump is the Saginaw type there is a way to reduce the pressure and give some road feel back.
As for 4-bbl swap, I've done it on a few engines (2 318s and a 360), it really only picks up power above about 2500-3000 rpm so if you have stock 2.xx gears you won't really feel it unless you're revving it out in 1st gear or passing on the highway. If you have 3.23+ gears then it's a different story. Plus if you go with a common aftermarket carb they're easier to get tuning parts for. Then again like others have said most factory 4-bbl intakes you'll come across are the spread-bore type, can make them work with an adapter to a square-bore carb but it's not exactly ideal.
Isn't that the main purpose for a 4bbl, passing.
I read through your post and didn't see where you were having an issue with the steering. Somehow we got sidetracked?
Poke around in the steering/suspension forum. Mopar's were known for over zealous P/S and a loose feel. Some have shimmed the pressure valve in the pump or gear to reduce the assist. Aftermarket companied like Firm Feel or Steer and Gear have rebuilt gears that improve that loose feeling.
