[Found!] 2 long bolts to join manifolds together
gdizzle
los angeles
I am in search of 2 hex bolts, 5/16 - 18 x 3.5inches long to join my exhaust maniolds. must be fully threaded.
I scoured the net, only to find boxes of 10 or 50. and crazy shipping costs.
Anyone have some to spare? Thanks
slant 6 super 6
why do you think you need fully threaded bolts? they go through the intake and thread into the ex. as i recall there should be enough room for 1 1/2 to 2 in. of shank.
slant 6 super 6
I may have them if I can find them
Currently using 2 threaded rods, with a nut on each end. PITA to take off and on. Needs to be fully threaded or mostly threaded as the ends have to stick out 1/2in for me to attached the throttle bracket for super six.
After no luck, I took your advice and just cut my own threads into a bolt I already had. Easier than I thought. It was actually some original long (4 in) bolts that came off my 1bbl manifolds. And in my tap/die tools I only own 2 Dies, one happened to be the 5/16 - 18. Then I just hacked off .5 and I am good to go. Thanks guys.
