225 Max Performance Recipe?
Slant 6 Engines
  1. Nofences
    Nofences Member
    8
    0
    Nov 7, 2017
    Massachusetts
    Local Time:
    10:49 PM
    Hi All
    I'm new here and working on my first project.
    It's a 73 Swinger. Pulled the 225 and sent body to blaster.
    I am trying to decide which way to go for power.
    Either swap the 225 for a 340 or 360 build. Or maybe build out the 225 I already have.
    Any insight on this? What HP can be realized from a 225 with mods? Any recipes for success?
    I would also like to be able to drive this on the street.
    Thanks
    Dan
  2. rumblefish360
    rumblefish360 So close, yet so far away
    36,941
    8774
    Jun 21, 2005
    New York, on a Island
    Local Time:
    10:49 PM
    Dan! Welcome aboard!
    I have seen /6 engines power a car into the low 11’s. Just the engine. No blower, no turbo, no laughing gas (N02). However, streetable is also a term that is very loose and dependent on the person driving the car and what there willing to tolerate.
    On that note, the larger the engine the easier it is to make power and the ability to run quickly. IF you want to swap the 225 /6 for a small block, I honestly would skip over the stock stroke of the 340 or the 360 and make the move to at least a 4.00 crank for 408+ cubic inches. The stroker does really well in torque production, the very thing your car needs to get moving. With a good head on top, (A well ported Edelbrock head at a min.) it will produce excellent up to keep moving really well.
    There are swap kits on the market for the ‘73. Schumacher creative services is the place your looking for.
    You will alsnever need a small block transmission and a upgraded rear.
    The /6 transmission will not bolt up to the small block and the rear is probably a tiny 7-1/4.
    A big block is also possible to bolt in without to much fan fare.
    • Agree Agree x 2
    • Like Like x 1
    • Charrlie_S
      Charrlie_S Well-Known Member
      2,763
      649
      Oct 17, 2005
      Silver Springs, FL
      Local Time:
      10:49 PM
      Slant six's have made approx 600 hp. Do you have cubic dollars. Something like that is race only, not for street. It is possible to build a slant for street use, in the 300hp range, but that is with a super/turbo charger.
      Dart270 on slantsix dot org, has a Dart 225 turbo, 200r4 trans. He drives to the track (sometimes several hundred miles) gets low to mid 20's mpg, changes tires, and runs high 12's in the 1/4.
      You need to determine how you will use the car, and what you want out of it.
    • UDUST81
      UDUST81 Well-Known Member
      469
      171
      Jan 5, 2014
      Des Moines IA
      Local Time:
      9:49 PM
      if youre gonna switch to a small block youre gonna need new motor tranny, rear end, headers, etc, might as well take the plunge and go big block
    • armyofchuckness
      armyofchuckness The Flying Valiant
      689
      107
      Aug 23, 2008
      Gainesville, FL
      Local Time:
      10:49 PM
      Slant Six mods can be rewarding, but you're never going to get the bang for your buck that you would with a V8. I only recommend Slant Six tuning if you really love the engine and want to do something that really stands out at shows. If you want to go fast, go with the 340. If you want to go slightly less fast for less money, go with the 360.
      • Disagree Disagree x 3
      • diymirage
        diymirage HP@idle > hondaHP@redline
        17,207
        10449
        Oct 12, 2012
        michigan
        Local Time:
        10:49 PM
        this only holds true in stock blocks your not doing anything to, other then dropping it in
        the difference in core price between that 340 and 360 can easily mean you can afford to put aluminum heads on that 360, while keep the stock unported heads on the 340
        if you intend to do ANYTHING to the block, go with the cheaper, bigger faster 360
        • Agree Agree x 4
        • Like Like x 1
        • cdnEHbody
          cdnEHbody Well-Known Member
          429
          128
          Oct 24, 2015
          regina sask canada
          Local Time:
          9:49 PM
          Id say unless you are planning to force feed the slant youll be dissapointed with dollars spent on a streetable n/a engine.
          • Agree Agree x 2
          • barbee6043
            barbee6043 barbee 6043 FABO Gold Member
            11,560
            4272
            Jul 20, 2008
            Shepherd, Texas ( SE Tx)
            Local Time:
            9:49 PM
            I know a guy that runs 10.0 in the quarter with a NA slant but he has $18000 in the engine alone!!!!!
            • Agree Agree x 2
            • Darter6
              Darter6 Well-Known Member
              4,008
              1221
              Jan 16, 2008
              Nevada
              Local Time:
              7:49 PM
              Yep, I spent $14,000. The guys at Indy Cylinder Head asked "Why ? You could have a Hemi for that." My response,"Because I wanted to.Anybody can have a fast Hemi,but a fast Slant,now that's something."
              Also raced it for over 10 years without fault or rebuild. So a cost of about $1400 a year.Worth it to me.
              • Like Like x 2
              • Agree Agree x 2
              • barbee6043
                11,560
                4272
                Jul 20, 2008
                Local Time:
                9:49 PM
                Might I add, that those of us that have run a stock 426 hemi and a stock 440, tit for tat, the hemi was only a smiggin faster in the quarter or for me, down a stetch of rural blacktop. Hemi is high priced eye candy!!
                • Agree Agree x 4
                • OldMoparFart
                  OldMoparFart New Member
                  1
                  1
                  Nov 27, 2017
                  San Antonio,TX
                  Local Time:
                  9:49 PM
                  I used a 1965 truck 225 block, bored .100 over using Buick 225 V-8 pistons with the wrist pins sized to the Dodge pins about 12:1 comp ratio, shop made 4bbl intake w/Carter AFB 450cfm carb, the Hyper-pack cam and valve train, Clifford header w/dual exhaust, stock 3spd trans with an 8.75 rear end. Built in the early 80's
                  stock 350 Chevelles could touch it.
                  • Like Like x 1
                  • rumblefish360
                    36,941
                    8774
                    Jun 21, 2005
                    Local Time:
                    10:49 PM
                    So super disagree. The 360 is cheaper due to way more engines produced. How does 20 more cubes make an engine slower? If such is the case, then why stroke with a 4.00 crank for 400 plus cubes? To go slower?
                  • Darter6
                    4,008
                    1221
                    Jan 16, 2008
                    Nevada
                    Local Time:
                    7:49 PM
                    Yep oldmoparfart, Suprised many a V8's.
                  • Nofences
                    Nofences Member
                    8
                    0
                    Nov 7, 2017
                    Massachusetts
                    Local Time:
                    10:49 PM
                    Wow, thanks for all the input!! So glad I found and joined this forum.
                    I guess if I want more wow factor at a car show then the 6 all dressed up would be the way to go, but if HP and Torque are what I’m after then I should go v8.
                    340 or 360 is the next question?
                    I figure 450hp would be more than enough for my little A body.
                  • MOPAROFFICIAL
                    MOPAROFFICIAL Well-Known Member
                    4,799
                    3809
                    Jun 1, 2016
                    Beach
                    Local Time:
                    7:49 PM
                    It will always be 2 short.
                    Put 12.5 pistons in it, race gas,port the head to flow 190-200 cfm by .550 lift, as steetable a cam in .550 range as you can get ground and 4 barrel carb and intake run 3.91 gears with a 4 spd.
                    "Snaps fingers"
                    Seriously, you'll get pushed around with that little motor unless you make it not very steetable.
                    Best of luck
                    • Agree Agree x 1
                    • cdnEHbody
                      429
                      128
                      Oct 24, 2015
                      regina sask canada
                      Local Time:
                      9:49 PM
                      Youll be able to find a 360 far easier. And cheaper, and can make the same hp just as easy. 360 had a far longer production run. A magnum 360 would be a good start. Shit a decent built 318 will boil the rubber off.
                    • rumblefish360
                      36,941
                      8774
                      Jun 21, 2005
                      Local Time:
                      10:49 PM
                      It’s a no brained IMO!
                      360, plentiful, cheap, 20 more cubic inches than a more expensive 340, a lot of it in stroke for more torque.
                    • MOPAROFFICIAL
                      4,799
                      3809
                      Jun 1, 2016
                      Beach
                      Local Time:
                      7:49 PM
                      Even 400 hp would make most happy.
                      Factory j 2.02 heads with a 3 angle valve job , kb 107 piston 360 short block with a .500 lift 284 duration cam ,headers, rpm intake w/750 will make about 390-400 hp on a bad day.
                    • Darter6
                      4,008
                      1221
                      Jan 16, 2008
                      Nevada
                      Local Time:
                      7:49 PM
                      If you DO the Slant,people will look at you,like you are strange........Believe me I know...
                      • Agree Agree x 2
                      • rumblefish360
                        36,941
                        8774
                        Jun 21, 2005
                        Local Time:
                        10:49 PM
                        I don’t know what cam your making a reference to but I remember the old MP create engine. 360/380. Same as above with there 284/.484 cam. I know it dyno’d more than 380, but not sure if it creates 400. Probably did.
                        The 280/.480 cam will make about 360hp @ 9.0-1, headers, 750....
                      • 273
                        273 Well-Known Member
                        2,940
                        731
                        May 14, 2012
                        Ontario
                        Local Time:
                        10:49 PM
                        You pretty much can take any V8 add cam 4bbl and headers and beat the hp of a built NA slant 6. Head is the /6 weakest area for performance.
                        Gearing is the next problem. Smaller displacement is gonna need a lot deeper gears to be on the same footing as V8.
                        If you want any real power some kind of power adder is needed.
                        I always wanted to build a /6 but it really pointless go 360 or 408 or even 440.
                      • Killer6
                        Killer6 Well-Known Member
                        2,372
                        771
                        Mar 9, 2015
                        PA
                        Local Time:
                        9:49 PM
                        1st off, Welcome to FABO!!
                        2nd, You have three primary considerations;
                        1) Ability........what are You and the people that may/will help You capable of & willing to learn/do?
                        2) Goals..........what performance do You wish/expect? For now & in the future. Do You know?
                        3) Budget.........how much capital will You be able/willing to expend for parts, materials, & work performed that You cannot?
                        Building a Slanty that runs is satisfying, but Hp/$ it is not a bargain, even if You are only buying 3/4 of the hard parts of a V-8.
                        I built one, and am working on phase III of the same .060" over unit I started running in '88.......long before I'd ever heard of Doug Dutra etc. etc., but I did it for the
                        challenge of making one of the more lethargic contemporary powerplants out there actually run. I also swapped a cammed 318, 4spd, & 8.75 rear into My 1st car, a '69 Dart
                        Custom w/a Slanty in it.......the one I built for My other project car. I had a S*#Tload of fun in both, but a lot more work & $$$$ in the Slanty project.
                      • emsvitil
                        emsvitil Well-Known Member
                        493
                        472
                        Mar 14, 2015
                        SoCal
                        Local Time:
                        7:49 PM
                        More slant info at slantsix.org
                      • barbee6043
                        11,560
                        4272
                        Jul 20, 2008
                        Local Time:
                        9:49 PM
                        I guess this type argument can be found on FBBO involving the poly 318, aka wide block poly, aka the A block, etc.....as it is called. Point is that engine can be made to have some pretty impressive numbers, (it has quite a following) , yes it costs considerable more to build, than an A,B, or RB engine, but the lovers of it, are sorta like us slant guys. Like being different, and the whole long list of why we love the slant.
                        I enjoy finding out all the characteristics of every engine or car model. The things I like, and the thing I do not. Plenty of negative and positives for each!!?????
                      • Darter6
                        4,008
                        1221
                        Jan 16, 2008
                        Nevada
                        Local Time:
                        7:49 PM
                        Yep, I had a pretty hot Poly too ! I guess I'm Slanted differently.
                        • Like Like x 3
