PocketAces
Below are the results of a compression test on my 1965 273. The car has a 1969 short block with 1965 heads and manifolds. It's a 2bbl and I doubt the block was a hipo/commando. Since the block does not have a VIN stamp, I'm thinking it was a warranty replacement.
The engine runs fine with no symptoms of oil consumption, or blow by. It's no racer, but then I'm not really sure what to expect from it. Mostly, I'm just trying to decide what I should do with it when I restore the car. If it needs a rebuild, I think I would hunt down a 1965 block. But if it's healthy then maybe I just refresh the heads. The previous owner stated that the engine was rebuilt in the 80's and then driven maybe 30K miles since.
The numbers are after 5-6 compression strokes, basically once the gauge stopped climbing.
Here are my questions:
- I forgot to open the throttle plate, should I repeat the test?
- What is a healthy reading for this engine?
- If the engine was a warranty replacement, what cam would it have come with? I think they were using hydraulic valves by 1969. Not sure if I have adjustable rockers or not. Need to pull the valve covers.
- What is a typical increase for the wet test? Does +10 to +15 indicate healthy rings?
- What's the next step? I think I should check the valve lash to make sure the valves are closing all the way. I could do a leak down test, or I could just pull the heads and have a look.
