273 Damper/Harmonic Balancer Differences?
Bossanova5
Los Angeles
Hello all,
I have (2) 273's.
One 66 273 two-barrel Single pully belt (no P/S or A/C) damper which has two balancing holes drilled in it.
One 66 273 Commando Double pulley belt (With P/S) has four balancing holes drilled in it.
Can I interchange the dampers between the two engines?
Thanks
Hello all,
I have (2) 273's.
Thanks
Both are neutral balanced engines so they should interchange.
