Hi all.
After some advice please.
Are these 273 adjustable rockers?
I can see the tops of the lifters and they are hydraulic.
The push rods are ball and cup.
I am thinking of pulling them off to see if they can be shimmed better because some of the rocker arms don't cover the valve stems fully. Surely this is not optimal.
Am wondering if this has been done to make sure the oiling works.
But as I have never seen these Mopar adjustable rockers before wont know how it works until I remove them and inspect.
Question is..... How do I set them up when I put them back together? (adjustments, torque settings etc.)
Here are some pics, Your comments are most welcome so I can learn about them.
First pic shows that the rocker on the left can not go any further to the left so it will cover all the valve stem because the 'retainer' or whatever it is called, under the bolt is stopping it.
Second pic shows that these two rockers can float left or right.... maybe they need more shims on the shaft?
Third pic shows that there are 2 different size 'retainer' things under the bolts.
Is it possible that whoever put them on got it wrong and the 'retainer' should go small-large-small-large-small and NOT large-small-small-small-large?
Thanks
Thanks
