284/484 camshaft
shadetree69
Member
waterville, ohio
has anyone ever used this cam in A 340 A-body and would A 3000 converter work well with it ? my 69 dart is stock weight, lightly ported j-heads(2.02) 10.0 compression, air gap intake 3310 holley, 3.73 gears, full length street headers with dual 2-1/2 exhaust, thanks for all the help
I have one in my 68,360 jheads performer rpm 650 dbl pmpr 9.5 cr,2800 stall,3.23 gears,ss springs.It is one fun ride.
As long as you get a good one it should work fine. Not as good as a modern grind, but decent nevertheless.
The reason I said "as long as you get a good one" is because the last one I degreed in was 8 degrees off. I have heard of quality issues with them from others too.
Agree with fishy, they are a little long on duration which looses a little low end left on the table, but it should be ok!
But if you are getting a new cam look at the comp cams in the 268 or so grinds, more likely a better combo for what you are doing.
good luck:)
Had one in a previous 340 not impressed with it at all,they're MUCH better cams out there...
I had one in a 360 back in the 70`s. I believe you can probably find better grinds today but if you`re set on getting that particular cam, it would work well with your combo.
I had it in a 360 with a ld340 &x heads with adj 273 rockers hooker super comps 5204 i think 3500 stall turbo action reverse valve body 3.91 gears i ran very strong the secret is matching your parts that combo ran very well wish i had 3.73 gears instead of 391 i ran a 600 holley with vacum sec light weight spring get you a mopar speed secrets engine &chassis book it will tell you what to use sure help me best 40.00 i ever spent:toothy10:
