318 4bbl Conversion
Small Block Mopar Engine
  1. rustyfish
    rustyfish Well-Known Member
    514
    309
    Sep 15, 2015
    Kansas City
    Local Time:
    12:02 AM
    Gathering all the parts for my 4bbl conversion. I've got an ld4b and an edelbrock 1406 ready to go. Looking for heat insulator gaskets for the job but there seems to be no end to the square bore options for this piece. There are lots of different styles as well and I'm not up on all the differences so looking for recommendations.
  2. DesertRat
    DesertRat FABO Gold Member FABO Gold Member
    2,602
    1456
    Jan 22, 2005
    Moses Lake, Washington
    Local Time:
    10:02 PM
    With the ld4b you will want the insulator gasket #9266 from Edelbrock. I just installed my new avs2 with the open insulator gasket but the book calls for the number I gave you. Comes with the correct studs too.
    • Thanks! Thanks! x 2
    • rumblefish360
      rumblefish360 so close yet so far away
      33,478
      5539
      Jun 21, 2005
      New York, on a Island
      Local Time:
      1:02 AM
      X’s 2! Excellent gasket for the job!
      • Thanks! Thanks! x 1
      • rustyfish
        514
        309
        Sep 15, 2015
        Kansas City
        Local Time:
        12:02 AM
        Excellent, thanks!
      • Slantsix64
        Slantsix64 Well-Known Member
        1,093
        206
        May 11, 2014
        SGV
        Local Time:
        12:02 AM
        You also need the four barrel throttle bracket which you can but new, also the kick down lever at the carb needs to be extended one inch.
      • dibbons
        dibbons Well-Known Member
        2,667
        1045
        Nov 6, 2009
        La Paz, B.C.S., Mexico
        Local Time:
        10:02 PM
        Does a Thermoquad use the same insulator gasket? Or does it even need or use one? I am working on a conversion too. Thank you.
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        35,422
        17429
        Jan 18, 2006
        Iowa
        Local Time:
        12:02 AM
        Let us know how that carb works out.
      • DesertRat
        2,602
        1456
        Jan 22, 2005
        Local Time:
        10:02 PM
        Hard piping and installing the cheap fuel pressure regulator now, taking my time trying to anticipate all the glitches
        • Like Like x 1
        • DartGTDan
          DartGTDan 70-71 Dart GT Fan
          856
          407
          May 29, 2004
          Detroit Metropolitan Area
          Local Time:
          1:02 AM
          Yup, #9266 is what I used for my LD4B/1406 swap.
          • Like Like x 2
          • Agree Agree x 1
          • toolmanmike
            35,422
            17429
            Jan 18, 2006
            Iowa
            Local Time:
            12:02 AM
            Nice drop base air cleaner. Edelbrock piece?
          • DesertRat
            2,602
            1456
            Jan 22, 2005
            Local Time:
            10:02 PM
            No, The valve covers are real Cal Custom that I cleaned and powercoated. I cant remember where I got the air cleaner but I bought it to match the valve covers and I think it is Cal Custom as well. I finished the fuel plumbing and I am ready to start the car. I will make it a morning project as I need to think about it and review all the advice the players in our conversation gave me. (you know who you are)
            I am cautiously optimistic that I will have a good outcome and my little motor will finally run. As one said-all this for a vacuum leak that I should have been able to diagnose 2 years ago------------------------I feel really inadequate----------but hopeful!
            • Like Like x 1
            • Slantsix64
              1,093
              206
              May 11, 2014
              SGV
              Local Time:
              12:02 AM
            • toolmanmike
              35,422
              17429
              Jan 18, 2006
              Iowa
              Local Time:
              12:02 AM
              You'll be fine!
            • H22A4
              H22A4 Well-Known Member
              1,485
              364
              Aug 4, 2006
              YVR
              Local Time:
              10:02 PM
              • Like Like x 1
              • Agree Agree x 1
              • rustyfish
                514
                309
                Sep 15, 2015
                Kansas City
                Local Time:
                12:02 AM
              • toolmanmike
                35,422
                17429
                Jan 18, 2006
                Iowa
                Local Time:
                12:02 AM
                It has been reported that duals are a nice addition. The factory manifolds are a bit restrictive, 340 manifolds a bit less and headers are the ultimate but not absolutely necessary for a teen with stock compression, heads, and cam.
              • rustyfish
                514
                309
                Sep 15, 2015
                Kansas City
                Local Time:
                12:02 AM
                Right now I just need it to be a driver. It's been so long already. Once this project is done, then my winter project will be to tear down the front end and have it ready to cruise for the spring, finally!
                • Like Like x 3
