68383GTS
OK I have a 73 318 and a 67 273 Bellhousing and flywheel.The bellhousing will work on the 318 but the flywheel will not,right???
The reason is because the 67 273 has an internally balanced steel crank and the 73 318 is a cast crank that is externally balanced.
Nope. NO 318 was ever externally balance. You're right about the 73 havin a cast crank though.
