318 build for light weight BCuda 4 speed car
Mopar Racers Forum
  1. ProStocker273
    ProStocker273 MoPar N Jeep
    473
    85
    Mar 20, 2013
    Puyallup wa
    Local Time:
    7:42 PM
    Picked up at 73 dart for $450 with 318. Just pulled apart engine. I lucked out with a .30 over motor with KB 167s that sit +.01 above deck. Crank is -.01 under and looks to be fully machined and balanced. Heads turned out to be 596s with 2.02/1.6 valves already installed and have been decked down to 63cc chambers so guessing probably been cut -.05 on head surface.
    I have a stock 65 4 speed in my barracuda now but have a complete aluminum overdrive 4 speed I just picked up I'd like to eventually run as I've have a 8.25 rear end with 4.56 gears and locker. So both have a 3.09 first gear but the over drive has a almost 3000rpm drop going into second gear but like the idea of the .71 overdrive. Which might be better trans for this combo? Planning on 30" tire as well. Home built 1-3/4 long tubes into 3" collector.
    My barracuda is 2800lbs with almost finished mini tub and super stock springs and 73 dart bb discs. Currently have a built 273 with a tunnel ram with two holley 450s that runs great but planning on swapping in the 318 block/360heads (ported) in this winter. I'll be running 93 pump gas, i have manual brakes so manifold vacume is no concern. this is not a daily but do street drive car around town. My local track is at 100ft about sea level. I plan on running a solid cam with 273 adjustable rockers but looking for good cam with my combo. Wanting to go with a lunati cam but locking for best option to get me down the quarter quick and fast as I can with what I've got
    Hard to find good recommendations for a 318 with a tunnel ram in a light 4 speed car with 4.56 rear gears.
    • Like Like x 6
    • j par
      j par Well-hung Member
      17,180
      8326
      Jul 2, 2014
      Portland Oregon
      Local Time:
      7:42 PM
      Sounds cool I'll be interested in watching how this turns out...
      • Agree Agree x 2
      • 318willrun
        318willrun Stomper 4x4... we kept energizer in business
        10,939
        10107
        Sep 13, 2013
        I'm here
        Local Time:
        9:42 PM
        subscribed..... and cheering for you :D
      • mopardude318
        mopardude318 Well-Known Member
        9,600
        736
        Jan 7, 2005
        Gilroy, Ca
        Local Time:
        7:42 PM
        Very cool!
      • QKFSH67
        QKFSH67 Well-Known Member
        238
        85
        Dec 21, 2015
        Prophetstown, IL
        Local Time:
        9:42 PM
        Yeah buddy!
      • Syleng1
        Syleng1 Karma is real and Life is short... FABO Gold Member
        1,241
        828
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        10:42 PM
        Wow! A man who likes adventure!
        What sized carbs are you running?
        Syleng1
      • rumblefish360
        rumblefish360 So close, yet so far away
        36,027
        7919
        Jun 21, 2005
        New York, on a Island
        Local Time:
        10:42 PM
        1/4 or 1/8 mile car?
        What size wheel and tire will be raced?
        Exact, if possible compression ratio?
        Any porting work on the cylinder heads known?
        E.T. sought?
        Has the block been modified for high rpm usage?
        (AKA, blocked oil passages, opened up oil passages? Lifter bores modified, corrected, sleeved?)
        I personally don’t know anybody drag racing with the O.D. transmission. Being that Chrysler swapped where 3rd & 4th ride inside the transmission, many feel that the trans is week in overdrive. I myself never had the chance to put the screws to one of those transmissions.
        What is your finish line rpm at?
        As far as a cam goes, this is a widely, subjective and highly opinionated subject. A known tire size and compression ratio would help a lot and to a long way.
        For simplicity sakes, a solid tappet cam will do the trick.
        Now it is IMO that the cam should not only match the engine combo but also the rest of the drivetrain set up with an ET in mind to help select a duration @.050) number to get the operating rpm band where it’s needed.
        On lift, knowing where the heads air flow stalls is an excellent help in how much the valve can be lifted. On a race oriented set up, briefly exceeding max flow capabilities is ok and good.
        If your looking for a maximum output for maximum speed and lowest ET, a custom cam isn’t a bad idea and a call to a place like Bullet would be of great help and no nonsense. You do need to have your ducks lined up information wise.
        Your description above is a good general one but lacks important information needed for best results.
        If you want opinions on camshafts just for fun use, you can get them here.
      • toolmanmike
        toolmanmike FABO Staff Staff Member FABO Gold Member
        42,994
        26044
        Jan 18, 2006
        Iowa
        Local Time:
        9:42 PM
        This will be fun. The aluminum 4 speed will be a overdrive unit if it's a stocker.
      • rumblefish360
        36,027
        7919
        Jun 21, 2005
        Local Time:
        10:42 PM
        Oh crap, I forgot to add a worthless 2 cents of camshaft choice... LOL
        If I was running a 28 inch tire, something like the MP mechanical 284/.528 cam would work with the 4.56’s.
        (That’s around 240 @ .050 duration)
        I think the 296/.557 may be pushing it a bit.
        • Like Like x 1
        • JBurch
          JBurch Well-Known Member
          1,761
          867
          Oct 17, 2009
          Owego, NY
          Local Time:
          10:42 PM
          Don't have experience with a 4 spd, nor a Tunnel ram, but I did run a Teener in my 65 Back-a-ruda, my best time with it was 12.54, 108mph; full write up is in 12 second combos; tires were M/T 275/60x15 drag radials, basically a 28x9 tire, gears were 4.88's; engine was single 4 bbl, 904 tranny with 4500 rpm stall converter.......I ran a Comp Cams XTQ281s-6, it screamed.
          My opinion is that you could use less tire, ie shorter, or more gear.......30 inch tire is a lot of tire......you'll be fighting bog off the line...the OD 4 spds are not known as rugged units and I can't say that I have ever heard about people racing them; as you pointed out it's all about the gear spacing.....your 65 tranny would be a better choice as the gaps between 2nd, 3rd, and 4th are closer together, the rub there is the trunion flange, I think but I am not 100% certain that you could swap the 65 guts into the aluminum OD case, use the OD main shaft, get rid of the trunion flange and some weight.
          Good luck!!
          • Thanks! Thanks! x 1
          • yellow rose
            yellow rose Doctor of Thinkology.
            18,482
            14530
            Jun 19, 2015
            Living on the razors edge
            Local Time:
            7:42 PM
            Call someone and order a cam. No need for an off the shelf cam with what you are doing. You'll need a lot less seat timing with the TR and a faster lobe.
          • ProStocker273
            473
            85
            Mar 20, 2013
            Puyallup wa
            Local Time:
            7:42 PM
            Currently not really looking to pay for custom grind but looking at one of luntai Voodoo Solid grinds.
            Its 278/278 duration .570/.570lift 251/251@.050
            105/99. Operating range of 3000-7000 rpm.
          • ProStocker273
            473
            85
            Mar 20, 2013
            Puyallup wa
            Local Time:
            7:42 PM
            I'm gonna get on the phone with lunati next week and see what they recommend. They have another cam I really liked but it says 10.5 minimum compression. Most I can get out of my setup is gonna be 10.2-10.4.
            It's a Voodoo series hydraulic flat tappet cam but i would run with solid lifters. Its speced at
            284/292 .533/.552 lift 242/252 @.050 110/106
            Says cam rpm range is 2500-6600rpm but again says minimum 10.5 compression.
            Currently running 36° timing with the distributor locked out on the 273 and runs great.
          • ProStocker273
            473
            85
            Mar 20, 2013
            Puyallup wa
            Local Time:
            7:42 PM
            Thank ya
          • ProStocker273
            473
            85
            Mar 20, 2013
            Puyallup wa
            Local Time:
            7:42 PM
            Yes Sir, pulled it out of a 84 Ram 318 truck. Was gonna buy motor and trans for $200. Guy messaged me couple days before I went to pull em and said he would like to keep the motor but if I came out and helped could have the OD 4speed and all associated parts for free. Hell if a deal.
            • Agree Agree x 1
            • ProStocker273
              473
              85
              Mar 20, 2013
              Puyallup wa
              Local Time:
              7:42 PM
              The my are holley list 9776 450cfm mechanical secondaries with no coke horns. I jetted them down 6 sizes from stock and changed the pump cams from the pink to the green. Fires up quickly but gotta feather the gas till its warm. Throttle is crisp and I have not hesitation which is little suprising on a 273.
            • rumblefish360
              36,027
              7919
              Jun 21, 2005
              Local Time:
              10:42 PM
              IIRC, member 408cuda, if the screen name is correct, runs that cam in his ride to the tune of 11.1’s. His engine is a 408 (duh) and Edelbrock efi. @ 11-1 with ported Edelbrock heads.
              I think your certainly in the ball park of the goal sought.
              I just don’t know about the OD trans. I have one as well I was hoping to get into a street strip Duster.
            • vntned
              vntned Well-Known Member
              1,128
              597
              Apr 28, 2012
              Gibsonville NC
              Local Time:
              10:42 PM
              Run away from the overdrive. The gear spread SUCKS fo racing, or enjoyment.
              And on an early a keep the tire in between a 26"-28".
              As described, it'll look cool, sound cool, but won't work well.
              • Agree Agree x 2
              • yellow rose
                18,482
                14530
                Jun 19, 2015
                Local Time:
                7:42 PM
                Usually a custom cam is the same cost as an off the shelf cam.
                • Like Like x 1
                • Agree Agree x 1
                • toolmanmike
                  42,994
                  26044
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  9:42 PM
                  Nothing wrong with hopping up a 318. Kinda cool actually. What kind of 1/4 mile times are you expecting? A 318/390 or a 360/408 stroker can get you into the 10's pretty easy. Just sayin'
                • rumblefish360
                  36,027
                  7919
                  Jun 21, 2005
                  Local Time:
                  10:42 PM
                  True words and! If it does cost a little more, it is worth it.
                  • Agree Agree x 1
                  • ProStocker273
                    473
                    85
                    Mar 20, 2013
                    Puyallup wa
                    Local Time:
                    7:42 PM
                    I have couple 360s but they are external balance which would mean me flywheel clutch bellhousing zbar clutch fork and my custom headers would then need redone as they tuck tight to the floor and bellhousing. So to go to the larger bellhousing for the external balanced flywheel for a 360 would be rather costly and lot more work. I'd be better off with a stroker cost wise. I dont see 18 ci less than a 340 and a bore .06 smaller than a 360 not capable of making power with head cam and compression. Plus I got this 318 machined block and 360 heads and all machined and ready for couple hundred bucks. I want to see what it will do as everyone building 318s is always a budget deal or a daily driver and most all are auto trans.
                    Eventually my 72 360 block will make its way in but not for awhile
                    • Like Like x 1
                    • ProStocker273
                      473
                      85
                      Mar 20, 2013
                      Puyallup wa
                      Local Time:
                      7:42 PM
                      Overdrive is down the road but will receive passion performance gear kit that evens up the spread and strengthens up the trans. Not too expensive of a kit
                      I will never run a smaller than 28" on a early A they look frumpy and it's not for me. My wheel wheels are getting stretched or radiused for a 30".
                    • my68barracuda
                      my68barracuda Well-Known Member
                      881
                      527
                      Dec 6, 2009
                      Indianapolis IN
                      Local Time:
                      10:42 PM
                      you do know that an a833 out of a D series truck is a long tailed transmission. The long tail a833 can be installed into an A body but it is not a bolt in, like an A or F body short tailed a833 would be. At the big block dart site there’s a template for an extension that gets the shifter pad in the correct location.
                      • Like Like x 1
                      • JBurch
                        1,761
                        867
                        Oct 17, 2009
                        Owego, NY
                        Local Time:
                        10:42 PM
                        Not sure what you mean by "frumpy"......this is what my Back-a-ruda looks like with a 275/60x15 drag radial
                        • Like Like x 2
