No you're good. You know everybody has their favorites.If you guys are railing on me for post #37;
clearly, that was in response to another poster.
I agree he 318 is a good engine and I have one sitting in the corner of the garage, but I wouldn't start there for a build. If I had no engine at all id be looking for a magnum 360 crate engine. ( there are things I dont like about 360, it would have to be changed to internal balance for instance...) I have always had 340s so I am biased, but I do acknowledge that the same things that can be done to a 340 can be done to a 318. Cam, pistons etc, how would one run 2.02s in a 318?, it would require an over bore, how far over can you take a 318 last I knew and by the book it was .040 over which makes it 4.031 or something like that.
3.91 plus .040= 3.95
At street power levels, the bore size difference from 318(3.91) to 360(4.00) =.090=2.3% means very little. The same cannot be said for the stroke difference; 3.315 versus 3.58 =.265=8%
The thing about a streeter, is it's a two-gear deal. No sane streeter is gonna be topping out third gear on a regular basis if he wants to keep his license and or car. So you might as well gear it to top out in second at around 65/75 mph, and make sure your brakes can scrub off speed in a hurry. So build for build, the 360 can hit more bases with fewer dollars spent.
the bases are;
rpm to the top of second gear
rpm at kickdown into first at say 32 mph
cruising rpm @ say 65mph. If you cannot cruise your streeter comfortably for a couple of hundred miles, then you really don't have a streeter. I don't care what anybody says, my car cruises at 65=2240, and I have cruised two days one way with no fatigue.
Ok so, choosing that comfortableness is a highly personal matter, but typically, I would say, that is, IMO, 2200 is comfortable, and 3000 is not. So the median is about 2600. For me, that is still too high, but everyone has an opinion.
Now, to cruise 65=2600 with 27" tires will require about a 3.23 gear. These will get you 65=2640 at zero-slip/ say 2750 at 4% slip, on the tach.
So that sets the stage for everything else.
the following is for an automatic equipped,3600pounder , all loaded up; With 3.23s,
cruising at 32 mph is then 1880 in Second gear, and at KD will be 3180 at zero-slip/ perhaps 3500 on the tach.
And top of Second will be 60=5240@zero-slip/perhaps 5770 on the tach.
So from that, we know the power-band has to be from 3500 to 5770 =2270.
Next; 300hp is a nice street power level, I wouldn't build for any less. And by 380hp, most of it is going to tirespin, so unless your plans include serious traction improvements, IMO, 380 is overkill. So then a happy median is 340hp.
A 360 will do that with ease; all stock internals, stock iron heads even, and maybe a 224 to 230 cam @155/160psi cranking pressure.
What's the 318 gonna take?
Well by the time you are done, the only things still 318 will be the crank,the block, and maybe the rods........ cuz you will have 340-ized the entire top end. So is it still a 318? Yeah sure like milk is ice cream.
I don't get it.
Back in about 1968, Ma put the 440-4bbl top end on a 383 with a 440 cam and thus was born the 383Magnum, so I guess this 340-ized 318 could be called a 318Magnum.
Oh but you love your 318, but for some unfathomable reason, you rail on the 360 which is just a stroked 340. Everybody loves a stroker...... unless it has a 3.58 stroke; somehow that is unacceptable.
I don't get it
Back in the early 2000s, when my car was fresh, I used to take it to carshows and drive-in meets, and such. And I would get an earful of "oh you shouldda built a 340; those were fast"........
Now, my 360 is a 4.04 x3.58= 367, so I switched to calling it a stroked-340, and that was the end of poo-pooing the 360. Now it was all "oohs and aahs".
I don't get it.
I have had several 340s some of which I still have and use as doorstops, cuz the 340 is "just a bored out 318/ destroked 360/ a tweener."
The 318 is and forever will be; "the little engine that thinks it can." It can hit each of the bases with a specific build, but it can never hit them all, nearly as well as a 360 can, in a 3600pounder.
The average power from 3500 to 5770 will never be, build for build,comparing apples to apples, as high as the 360. And the 360 will cost waaay less to make it happen. With KB107s and 63cc chambers, it falls together at over 10.5/1 Scr, all ready for that 230/110 cam; almost tight-Q and all. Just bore it, stuff it, and screw it together, & d-o-n-e.
But yakno,
from a 360 to a 408 is plus 13.33%; oou, everybody loves a stroker.
from a 383 to a 440 is plus 14.88%; oou, everybody loves a stroker.
from a 318 to a 360 is plus 13.21%; Alex, I'll take 318 for the; oou, I like my 318 factor, cuz it will do everything the 360 cannot do, Alex;
says the Ostrich with his head in the sand.......
I don't get it.
A streeter is not a drag racer. You might be able to build a competition 318 with unlimited rpm..... But that ain't a streeter, married to a specific streetable rear gear.
Oh sure put some 3.91s on it and you can have fun. But how far can you cruise at 65=3400/3500
Oh sure you might be able to squeeze out say 20mpgs with 2.76s, and a small enough cam to stay out of reversion,...... but you'll need to supercharge it to get that up to 340 hp.
I don't get it.
Don't even get me started on
if you have a 4-speed........build for build and gear for gear; your teener is out classed on every front, hanging on with desperation.
I dont doubt it, what was he running to get compression up domed pistons I mean when you say "318" i am thinking low comp, flat pistons, small combustion chambers small ports, if you mean the only thing 318 is the block, thats different. Thats also probably the only usuable thing about a "318" performance engine2.02's fit fine on a stock 318 bore. Maybe you are thinking of a 273? I never over bore anything unless I have to, and then just enough to get straight round bores. Had a friend running dirt track with a 318 with X heads, custom cam from somewhere in NC. Fastest car on the track in a sea of Chevies and Fords.
I agree, and it seems to me that 318s are available,340s not so much. I have 340s and I have always felt that you start with the platform that will get you where you need to be. I was in tech school for automotive years ago, and a fellow student had a 6 cylinder Nova, talking about how hes putting a powerful small block in to make it a "sleeper" I said "you should start with a V 8 car to begin with to have that platform. Now youll need a trans and a rear to match the power out put. thats too much conversion work IMO. Its the same with the 318, if you need 340-360 heads, and machine work to get it there, why not start with the bigger engine? I have nothing against a 318, and i would use it as a base platform if that was all I had, and I am sure there are high comp pistons and all the same type parts that were /are available for the 340.3.91 plus .040= 3.95
the bases are;
I don't get it.
I don't get it
I don't get it.
But yakno,
I don't get it.
I don't get it.
The 360 was a smog motor you can do the same with it that you would a 318 to get performance out of it, it is already bigger bore higher flowing heads, its the displacement of air that comes into play here. I mean if its heads machine work cam etc that you do with a 318,its the same effort for a 360 really and in the end you are displacing more air. this discussion could go on forever I suppose, and I am not beating down 318s, I just wouldn't think of starting a build with one, I have the 340s I suppose that is just where Im at. The 318 I have is totoally stock internals, stock heads, I ran it with 3.91 rear and 4 speed, it was fun, on the street but it was restricted breathing at high rpms, i dunno it just fell flat at a certain point. I suppose heads would have helped. The 273 was replaced with the 340 for a reason as the Hi Po small block. The engineers knew what they were doing.Blah Wha wha wha. No one "needs" to go out and get a POS 360. I have built all MOPAR small blocks for the street. I don't play with numbers. We built engines, ran them, and tried all kinds of combinations. We used what we had. All engines have their advantages and disadvantages. I personally love 273's and 340's. I love high rpm's. All MOPAR small blocks can be made to run very fast with a little thought and a little money. What do factory 360 heads cost anymore with everyone thinking they have to have aluminum heads? Once again you are answering a question no one asked. The poor guy even said it twice. Never would I consider a 360 for one of my cars. I had them, built them for others, sold them all, even a HP with a factory shot peened CFD crank and windage tray. Still have three 340's, four 273's, one 318 Magnum, two 383's, and one HP 440 that I will probably never use. That does not include any of my early Hemi's. Tell me again about being outclassed by a stupid 360 again... and I run a 273 and a 4 speed.
I've been debating on building another 318 for my 73 valiant. My current setup is a 74 block STD bore, stock heads with a Hughes Whiplash 318 cam with an Eddy Airgap RPM intake topped with a performer 600CFM. Ignition is stock plugs with a Pertronix electronic distributor.
Transmission is a fresh rebuilt 904 with B&M shift kit stock converter. Rear end is fresh rebuilt 8 1/4 with open 3.55 gears.
Now don't get me wrong; I love the idle of the whiplash cam, and it is defiantly a whole different engine since I changed out the 7 1/4 that had 2.76 gears to 3.55's.
My biggest regret was not doing some port work, or gasket matching the stock Iron heads to the eddy manifold. But i've also thought about aluminum heads but don't really need 2.02 valves since this car wont see 5000-6000 RPM,(*1) I still want this to be streetable with the occasional local weekend 1/8th mile.
Indy made their indy X heads which came with 1.92 intake valves and were newly casted heads, but after talking with them they are looking for a new vender to make them for them again so they don't for see them for 8-10 months.
Looking to see what people suggest for a good set of heads new? or doing work to stock heads? Also what about cam specs? any suggestions?
I wanted a 340
I wanted a 340
Just searched speed master heads, have you had any experience with them? Are there a good quality head?
I would still like this to run on pump gas.
Ok, so to clear up the confusion. I have a seperate 318 core that is from 1973 that I plan to build. I would like it so be streetable with the occasional weekend fun. Its nothing that has to be done in a hurry so im not worried about costs. As mentioned above it would be smart to weigh out the costs of everything vs getting a stroker and making it a 390. Just would like to know what some good recommendations might be with stock heads, rods and pistons. And maybe what a good build would look like using a stroker kit.
I am not trying to build a 1/4 mile car, but maybe achieve 300 HP? Something reasonable out of a 318
I had to lolI am a 318 hater
I dont doubt it, what was he running to get compression up domed pistons I mean when you say "318" i am thinking low comp, flat pistons, small combustion chambers small ports, if you mean the only thing 318 is the block, thats different. Thats also probably the only usuable thing about a "318" performance engine.
hang on fellas;
the OP clearly stated that he wanted a 340,
found them too pricey;
but is willing to break the bank for a 300hp 318.
I was responding to the issue from;
the cost of things,
the ease of assembly, and
the fact that a hi-compression 360 can totally waste a lo-compression 318 as to hiway economy,
and still make plenty of power, easily eclipsing 300hp.. using all stock major components; and in the process, the 360 makes enough torque to annihilate the tires.
The OP is in no hurry, and is exploring his options, already moving in the direction that will cost big money, for, in a 318, very little gain; surely a recipe for disappointment........
I am merely presenting a logical argument to the OP, for a bigger SBM, based on less money having to be spent, as, the OP has already stated wanting a bigger engine; and, of the SBMs, the 360 is the best place to stick his 318Whiplash cam (*2) into, which already has large-port heads, and adequate valve sizes to work with that cam. The additional 42 cubes will nicely replace the bottom-end torque, that the Whiplash sacrificed in the stock lo-C 318; and so, OP can re-use the stock convertor and 3.55s, albeit with a SureGrip required. OP already has all the add-ons to make the 360 with the 318 Whiplash, a great combo!
If it ends up too powerful for the chassis, and it will, well isn't that just too bad.....lol.
(*1) the 318whiplash, in a 360, with big-port heads and AG will want a shift rpm of more than 5000, and you can wring it out to 5500 all day, with the right valvesprings. Speaking of rpm, the 360 under my hood, with KB 107s, has been spinning to 7000Plus, since 1999.
(*2) Hughes says that the 318Whiplash (213/226/109+5)( and lifts of .480/.516@1.5), works great in a 318, at "up to" 8.6Scr . OK, but there was no smoggerteen that was ever built to 8.6, so shame on Hughes for making you guess if it will work well in your STOCK lo-C teener. IMO Hughes is a lil slippery when it comes to camshaft specs.
Ima guessing your cranking pressure, in your sub 8.0Scr 1973 smoggerteen, is around maybe 145, so while it might be true that this cam works with 8.6, 145psi is about what a stock teener would put out in Indio. Read, lo-rpm pussyfied. OOps I mean soft.
The 360,will accept a lil more Scr; maybe something like 9.4/1, which is an easy build for a 360 with stock iron heads, and KB107s. That Whiplash cam has enough extraction duration, and a small enough overlap period, that it has the potential, at the right Scr, to make pretty good hiway gas-mileage. I mean, as to extraction and overlap, it's nearly identical to that of the 223/230/110Hughes, the one I used , to make 32mpgUSg. If anything, it's a lil better. You will, of course, not get close to that with 3.55s, geared 65=2900@ zero-slip, perhaps 3000 or more, on the tach; I was geared 85=2100 using a manual trans and overdrive.
(3) BTW, Biden has already stated that he is gonna raise the price of gas exponentially. So being able to run 87 gas and getting great fuel mileage, IMO, is sorta crucial to actually being able to drive the car, in the coming years. Biden and/or his party, is/are never gonna get voted out; they are here to stay. In the very near future, he is hoping to rid America of people, never mind gas-burning cars. In this scenario, a small cam 360 makes the most sense....
to me anyway.
I can't speak for the rest of you big-balled 300hp, 318 boosters.
In case you have forgotten,
here is a recap of some of the things that OP has said;
To be clear; I am not a 318 hater,
having had many many of them, in my 52plus years of driving. Almost all of our DDs have been 318cars. We have almost always been a two or three car family; one 318 car for me, a slanty-car for the wife, and a 340 or 360 bruiser for me to take out my frustrations on. With the occasional "other" car hanging around.
Btw
I would rather have a 340 shortblock with a 318 top and cam, than a 318 short with a 340 top and cam. It's really really hard to say no to the low-rpm torque increase.
As a streeter, yur only gonna pass thru the power peak once at WOT, possibly twice, and the first time don't count cuz the tires are melting. With 3.55s, the second time comes at around 65/70 mph........... Whereas the rest of the time, the engine will be lumbering along at 3000rpm or less..... probably closer to 2000, so.......... I mean, what good is 300hp at 5000, if the engine is sucked-out at 2000.............. On the street, you have a choice; 1) build the engine to have some honest torque, or 2) yur gonna need a hi-stall and near 4.xx series gears, AND an overdrive. I've done it both ways.
At 3600 pounds, I prefer a 360. That would be 10 pounds per cubic inch, a number hard to find fault with. My 1970 Swinger340 back in 1970, was 9.79 with me in it. It was slow; posting 98 in the qtr, versus 93 in the Eighth, for my Barracuda........
My 367 is nothing special, being built nearly the same as that 1970 340. The Scr is a true 10.95 compared to an advertised 10.5 for the 340. My cam is a 230/237/110 compared to the 340 being 228/236/114. Both were 4-speeds, had 4bbls, but my 367 has headers and full-length 3" duals. Yeah my 367 has OOTB Eddies on it so what.
The car posted that 93mph@3467 pounds, being shifted at 7000, well past the powerpeak of around 5100,lol. All in all, the advantage is just the headers, the free-flowing exhaust, and the 27 cubes. And the Barracuda was even a lil heavier than the Swinger.
They say that the 1970 340 made a tic over 300hp with headers and a good tune-up. Do you really wanna put that gas-hog 340 cam into your 318? And bump it's compression to 10.5, and make maybe 280hp; when the 360 in the same trim might make 320hp? In terms of dollars, is the cost of the 360 core worth 40 hp? Or a 5.9M? or even a 5.2M
Nah, "I like my 318", is the mantra.
Ok fine, there can be no argument against liking your 318. You like what you like, I get that. I don't like short,fat,black-haired girls. That doesn't make me a hater of short,fat,black-haired girls. If a short, fat, black-haired girl was the last girl on Earth, I would love her 17 children's worth. At least.
People throw the word "hate" out on everything, sorta like they brandish "racism".
Yes, but you are talking about a modified 318, adding parts that a 340 comes with stock. I believe what you are saying as it makes sense you could work 340 parts and specs into a 318, I am saying you are putting alot of effort into turning a 318 into a 340 when all you had to do is start with a 340 or A 360.It comes down to economics really I wouldn't spend that $$$ on a 318 if I really wanted a 340. I would fork over the cash for a 340 and start with that as a build, that or a 360. The thousandths of an inch in the bore does matter because it is displacement and air flow, the blocks can only safely be punched out so big, each bit of airflow through each cylinder adds up. It has been a long time standard that with a small block you want a 4 inch bore, you cant get there with a 318. I know its semantics but to each their own. Tis is almost like arguing 883-1200 in the Sportster worldNo idea what else he was running in his 318. I used to give him stuff for his race car. He did his own work. You guys still miss the point. You do not need a 340 or 360 to go fast with a MOPAR small block. The only thing basically different between a 318 short block and a 340 is piston diameter. A 340 bore is .13 of an inch larger. Do you really think that makes any difference? I hate to tell you but if you take 360 heads, cam, intake, carb, and distributor from a 340 and put them on a 273, 318, or 360 they all run pretty much the same, except for the rpm where the hp peaks. Maybe just a tad slower in the quarter for the smaller engines, not much though.
Yes, but you are talking about a modified 318, adding parts that a 340 comes with stock. I believe what you are saying as it makes sense you could work 340 parts and specs into a 318, I am saying you are putting alot of effort into turning a 318 into a 340 when all you had to do is start with a 340 or A 360.It comes down to economics really I wouldn't spend that $$$ on a 318 if I really wanted a 340. I would fork over the cash for a 340 and start with that as a build, that or a 360. The thousandths of an inch in the bore does matter because it is displacement and air flow, the blocks can only safely be punched out so big, each bit of airflow through each cylinder adds up. It has been a long time standard that with a small block you want a 4 inch bore, you cant get there with a 318. I know its semantics but to each their own. Tis is almost like arguing 883-1200 in the Sportster world![]()
I never cared for standards. I disprove them every day of my life. A 4 inch bore means nothing. My 273, with a 1.88 intake 340 top end and cam, ran the same as AJ's 340 in the quarter mile with Early A factory exhaust manifolds and 2" duals back in the day. If I had a good 318, I for surely would not trade for a 360. Heck I didn't trade a 273 for one, and I had 360's laying around. I would never bore any block more than just enough to clean up the bores. That is not where you make power. As for AJ's 360, how much money is in that thing. 11:1 compression and Edelbrock heads? I don't need any of that either. Trying to put that up against a low compression 318, what a comparison...
yep, he shows up, i start scrolling, sounds like charlie browns teacher!Has AJ ever built a Teen? I don't have the time to read through all his posts to find out.
the roller cam 318s with 302 heads the 80s were rated somewhere in the low 9s for compression were they not?hang on fellas;
the cost of things,
to me anyway.
Btw
Those were great engines.the roller cam 318s with 302 heads the 80s were rated somewhere in the low 9s for compression were they not?
SEE! The 318 hater spends a ton of time furtherly proving his Hatred of the 318!
yep, still have one in garage,plus 3 360s, that 318 took everything i threw at itThose were great engines.
Yea! LMAO, I knew a few chicks like that as well.took everything i threw at it
try to build a good performing 318, without breaking the bank
Transmission is a fresh rebuilt 904 with B&M shift kit, stock converter. Rear end is fresh rebuilt 8 1/4 with open 3.55 gears.
What would need to be done to run the 65cc heads on a 318 lower end?
I don't mind changing pistons out to boost compression,
I would like it so be streetable with the occasional weekend fun.But i've also thought about aluminum heads but don't really need 2.02 valves since this car wont see 5000-6000 RPM
Already have a excellent 318 core, already have a left over gasket kit, rings and some other 318 components. I would just be looking a some heads, cam, and decking on the heads.
AJs build and yours ,it sounds like two different engines for two different uses are you drag racing your 318? I am in the middle of a 340 build that I am trying to keep "as stock as possible" as far as cam, heads ,compression...I want it to run on pump gas and not over heat in traffic etc. The point with my 340 is, it had all the good stuff stock. A gasket set is all I would need basically... I believe it is possible to have a 273 in a 65 barracuda that moves that car scary quick...but that is a street car. Take that car to the strip and try to compete, and eventually out will come the 273 and in would go a race worked 340-360. it would come to that naturally I believe the 318 would only get the car to a certain bracket and it would stop there. However I am not up with the times and do not know what is out there as far as 318 internals for racing engines. I am fairly certain the heads would have to go , the stock 318 heads. Just my thoughts and I could be wrong. I figure the truth is 318s are drying up, and 340s have all but dried up, they definitely aren't cheap, and figure the things you have to know, what years did they go low comp, what valves are in what heads, internal vs external balance etc. I'm not sure 318s have that issue is there an external balance 318LA engine? Keep in mind I always talk in terms of LA I am not all that familiar with the magnum, I know a little about them but never owned one. I like the roller cam setup in the magnum though that makes sense to me, and i wish it was in the LA![]()
