I thought it was already spoken for?Perhaps, but it will be for sale at the conclusion of the dyno testing, so not a "set on kill" type build.
That's the 408 in the cylinder head dyno testI thought it was already spoken for?
I have never used thoseDo you have an opinion on the comp dlc coated lifters?
oh ok. So if I wanted the 318 for Vixen.......That's the 408 in the cylinder head dyno test
Who exactly are you talking to here?If you have good pistons and a quality balance rpm is your friend on a small displacement engine, it’s the only way you can increase displacement. Good head work and a cam that will make max hp around 6300 will give you 30 plus hp over your 5000/5500 limit.
They are excellent and priced right. At least for a Chevy. J.RobI have never used those
Supposed to be available soon for mopars. We'll see.They are excellent and priced right. At least for a Chevy. J.Rob
Be curious to see how this engine turns out.
I ran this engine( in the below link)at the track with a cam similar to what is being planned for this build( not the 248@50 cam this motor was dyno’ed with) and it had enough grunt to run right at 116 mph at 3400 pounds in a 71 Duster street car with full bench seat interior, factory 5/16 line stock gas tank setup.
https://www.hotrod.com/how-to/0901phr-mopar-318-magnum-engine/
Thanks for the link! That's a good read. This one wont be anywhere near as scienced out, and certainly wont make that much power.Be curious to see how this engine turns out.
Like Adney said in the article, the crank work likely won’t/ didn’t show on the dyno, but is a benefit at the track.Thanks for the link! That's a good read. This one wont be anywhere near as scienced out, and certainly wont make that much power.
It was an engine masters motor I bought.did you own the crank shop they talk about or just had work done there?
So this is more of a PSA update, but while getting it ready to line hone, I remembered ARP has finally updated the stud kit to include bolts for the rear cap, (where people would reuse a stock bolt for clearance to the pump.) That's GREAT, but you must make sure the bolt holes are bottom tapped deep enough for the bolt to clamp the cap before bottoming out! 318 caps are shorter than 340 caps, making this a critical check! I have seen a 340 with a broken main saddle due to this!
Yes!Rodney the 318? As in, “I get no respect” Rodney?
I like it.Yes!
