get the compression and report backSo, I will get a compression test done. Just need a few more days.
I believe that the carb is lean. It runs a lot better while the choke is partially closed and cold. At the very least tomorrow, I want to put a larger squirter in it.
Is there a spark plug that I should use with the 10-15% ethanol gasoline that would be better than the Champions? I'll order them from Rockauto.com and have them here by the weekend.
Yeah, my elevation is darn near sea level. There is a point at the inlet, it seems like the road goes below sea level at the base of the bridge, but the dunes give it that optical illusion.
Thanks for everything and I hope to get something done tomorrow
the carb is likely lean, so you'll need some jets to fatten it up.
the squirter only effects the initial crack of the throttle as the butterflies open and introduce more air an immediate richening event needs to occur or the car goes lean and falls flat on its face.
so in essence, if the jump off the line is good and it's not popping and farting or falling down or bogging hard, changing the squirter yields nothing.
